Help I really messed up!
Playing around with the MPROG3 utility, I over wrote the device definition for my usb to serial (RS-232) device that I purchased from Parallax.
Item code 28031 which includes the usb cord. Or Item code 28030 as seen from the online store.
Now it no workie with my SXKEY.
If anyone has one of these devices and wouldn't mind taking a snapshot of the mprog device setting and sending them in an .ept file I would really appreciate it. Matter of fact I will worship the ground that you walk on.
Mama always said "it's all fun and games until someone looses an eye..." Watch out playing around with the MPROG3 utility when you have more than one device attached.
Or post it if you would like.
Thanks and best Regards,
JJ
jonkzak@earthlink.net
Think you’re a Big-Shot?
Try ordering someone else’s dog around.
Jon K. Zachary
Katy, TX
JJ
Jon K. Zachary
Katy, TX
I think the real problem is in the CBUS pin settings that is causing my trouble as I didn't take a snapshot of this device.
Best Regards,
JJ
Jon K. Zachary
Katy, TX
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
CBus 1 pin used for Red Led
Cbus 3 pin used for Green Led
Cbus 0,2,4 'Sleep'
thanks Joshua...
JJ
Jon K. Zachary
Katy, TX
