Encapsulating to prevent condensation
I have an outdoor project that involves the use of a BS-1 stamp, what worries me is because I know it only takes one drop of condensation on it to shut it down would encapsulating it along with the other circuitry in epoxy·be a good idea·? The external connections (non TTL level) would be made by soldering magnetic wire to a terminal strip that is also embedded in epoxy except for the terminal connections points. Note the three serial port wires would·be wired to·a screw down waterproof type plug.
Post Edited (AJ-9000) : 2/2/2008 9:05:46 PM GMT
- Stephen
Careful, some epoxies will soften the rubber insulation on the wire.· If you meant enameled copper wire instead of "magnetic wire", that would probably be ok if it exited the epoxy’d circuit as long as it was thick enough to adequately handle the power requirements of your circuit.
If your epoxy requires a promoter,·lean towards the smallest amount of promoter required... if the epoxy sets off too quickly, it can damage your circuit components by excessive heat and/or create bubbles in the epoxy causing stress on the components as it hardens.
Beau Schwabe
IC Layout Engineer
Tracy Allen
www.emesystems.com
BTW, shoe goo or shoe goop is great stuff for waterproofing.· Much, much better then clear silicon.· Use it to hold large or heavy components to the PCB.· A small dab on wires going into headers will act as strain relief.· Absolutely great stuff...good for putting the soles back on yourf shoes...
Deno
