Another set of eyes
This code right here· I want to take in values from 100 to 220 and send over xbee wirelessly. I get it to send the numbers just fine but included is the start symbol too. My first question is how would I get rid of the "$" after the number is read in to just display the number. My next question is when I add the case statement in it acts all funny. I just want it to compare the whole value. This is to control and ESC for a foam jet using a keyboard (testing phase now until I can implement the joystick with throttle
Hunger hurts, starvation works!
{{XBeeSpeedControlDemo.spin}} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 pin = 4 CR = 13 VAR long idx, cptr byte throttle[noparse][[/noparse]256], prevThrottle[noparse][[/noparse]256], bFound, XBbuff[noparse][[/noparse]40], dataIn OBJ ESC : "ElectriflyESC" XBee : "XBee_Object" Term : "FullDuplexSerial" PUB main 'Setting up XBee to start recieving on this end XBee.start(10, 9, 0, 9600) XBee.AT_Init XBee.AT_Config(string("ATAP 0")) ' Set for non-API mode (AT mode) XBee.AT_Config(string("ATDL 1")) ' Set Destination Location to 1 'Setting up serial port params for debug term Term.start(31, 30, 0, 19200) waitcnt (1_000_000 * 25 + cnt ) 'Initializing the ESC 'ESC.initialize 'ESC.delay(500) readData PUB readData repeat dataIn := XBee.Rx if dataIn == "$" ' ASCII $ characte bFound := 1 if bFound == 1 if dataIn == CR throttle[noparse][[/noparse]idx] := 0 idx := 0 bFound := 0 Term.str(@throttle[noparse][[/noparse]0]) Term.tx(10) Term.tx(13) else throttle[noparse][[/noparse]idx] := dataIn prevThrottle[noparse][[/noparse]idx] := throttle[noparse][[/noparse]idx] idx++ case @throttle & @prevThrottle @throttle > @prevThrottle: Term.Str(String(10, 13, "Throttle increase: ")) 'ESC.throttle(pin, throttle) @throttle < @prevThrottle : Term.Str(String(10, 13, "Throttle decrease: ")) 'ESC.throttle(pin, throttle) OTHER: Term.Str(String(10, 13, "Throttle did not change: ")) 'ESC.throttle(pin, throttle)
- CASE is not what you want; read Chapters 3 and 4 of the Manual to learn more about SPIN
- To compare numerical values you have to convert them into binary format... lots of examples everywhere, as this is a typical beginners problem every week
Nevertheles, just use numbers#DEC as format and it might work...
