Reusing PCB echant.
I just talked one of the guy at the electronics supply shop when I buy parts, He told me that it's possible to reuse PCB etchant (the dark Iodine looking stuff). you can remove the suspended copper through electrolysis. I haven't tried this yet so I don't know the ins and outs of it yet but that will save me a few bucks!!!. ThHought I would share the info.
anyone else try this?
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
DGSwaner
http://en.wikipedia.org/wiki/Iron(III)_chloride
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I almost went with the muriatic acid route because of cost, but I decided to stick with what I'm familiar with and reclaim the copper
DGSwaner
Sure, muratic acid works, but it is very aggressive and easily over-etches. I suppose that it is buffered with the peroxide to prevent this. The ferric chloride is a traditional etchant from intaglio printing on copper plate and offers more control of fine details.
Artist occasionally add lemon juice - citric acid - to enhance the ferric chloride. They claim this is a better formula, but it is hard to objectively document. The point is that the art world has a lot of information about etching copper plate which has evolved over centuries. If you want the best detail and tips on handling, it wouldn't hurt to consider their knowledge.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Post Edited (Kramer) : 2/2/2008 8:35:55 AM GMT
http://tech.groups.yahoo.com/group/Homebrew_PCBs/
Leon
There really isn't a 'set formula' as temperature is a big factor. Dilution is another factor. Some people use an aquarium heater to speed up the ferric chloride and the actual strength of the solution varies with use. In fact, a new solution seems to go slower than one that has some copper ions in suspension.
Nonetheless, there is always the problem of your quality going to nil if you speed things up too much with a 'hot batch'.
One factor for prolonged or uneven etching is not making sure that the copper board is spotlessly clean before application of transfer tracks ie after a period of storage the copper tarnishes.
better still use photo resist board which tends to not tarnish like clean copper does as it comes with a plastic peel off film.
Post Edited (skylight) : 2/3/2008 10:37:19 PM GMT
A Ferric Chloride stain is also the most unforgiving stain you could ever create.· I continue to prefer the risk of undercutting to the annoyances of ferric chloride.· I also re-use my etchant and will only start fresh when it gets to be an unearthly shade of green.
As I've stated in the past...· Ferric Chloride gets it's color by an infusion of RUST.· It is essentially weaker·Hydrochloric Acid·[noparse][[/noparse]unlike the watered down·Hydrochloric Acid·we call·Muriatic Acid] (HCl) with rust in it·(FeO(OH)).· Why is that?· In steel rolling mills, they clean the rust (oxides) off sheet metal while it's being processed·with hydrochloric acid.· What we etch with is the liquid that results from that process...· a weakened acid.. There is nothing magical about the Iron in it.
There's nothing like a new idea and a warm soldering iron.
Post Edited (pwillard) : 2/4/2008 4:44:00 AM GMT
So what kind of peroxide do you use: the drugstore 3% stuff, or something stronger?
"I've found a new home-made etchant that I really, really like. And it's very cheap, and widely available. It's made by adding 1 part Muriatic Acid (the common kind that's sold in hardware stores, which is actually 28% Hydrochloric Acid) to 2 parts Hydrogen Peroxide (the common 3% kind that's sold in drugstores and pharmacies). This etchant can etch a 1-oz board in about five minutes, at room temperature, with gentle mechanical agitation. And it's almost transparent. I mix it in a small plastic food-storage container and wear rubber gloves so I can use a balled-up paper towel to gently wipe the surfaces of the board, as it etches, which seems to speed up the etching time, considerably. (Caution: The concentrated acid's fumes would be very bad to breathe, or to have around metallic items. And the acid would be very bad to get onto anything that's not plastic.)"
With most circuit boards, we have a lot of lattitude in the quality that is acceptible. So, the choice of etchants may simply come down to clear or that soupy rust colored stuff. [noparse][[/noparse]Yes, ferric chloride certainly stains quite well, but muratic acid eats holes in your shirts that don't appear until the next wash cycle and the fumes can permanently ruin your sense of smell.]
But as images get smaller and tighter, all aspects of quality control become more important. There are a lot of factors. I prefer the photo resist boards because they produce a near perfect image when used with a good transparency. Others use the laser transfer method. But I've never had the crisp, clean images that I enjoy with my prefered method, though some claim Pulsar's laser transfer system is excellent.
It is all about finding a method that suits your personal preferences.
Incidentally, ferric chloride is a wonderful solution to artifically age a bronze statue or brass hardware as it can create a powdery blue-green patina streaked with rust in a few minutes that would take years of weathering. Adding common table salt aids the process.
Be wary of anyone that is quite glib about working with strong acids, bases, solvents, etc. There are important proceedures for dilution and mixing to avoid fumes, explosions, and burns. The easiest precaution is to mix and use in an outdoor space. A plastic or rubber apron and gloves are always welcome. Chopsticks are handy for handling.
everyone talking about reusing enchant. from what I gather your just talking about taking a bottle etching a board and then reusing the same liquid the next go around? so your not actually reclaiming the copper and making the enchant usable again.
I didn't try the electrolysis method, due to chemical hazard concerns, but when the weather isn't so bad and I can go outside I'll try it.
DGSwaner
