LED pinouts
Has anyone ever used these and can help with some pin info?
LTP-3790JG - 2 character 14 segment per character display. 14 pins in 2 rows
LTP-14158AG - 5X8 LED array. 18 pins in 2 rows
They are both made by Liteon. I've asked them but haven't heard anything back.
Mark
mirk handwrote
admire nth work
Mark
mirk handwrote
admire nth work
The name of the game is:·Process of Elimination or Quality Time with Mr. Multimeter.
You can get LEDs to light, however dimly, with the Diode tester on most multimeters.
Make a diagram of the display, physically, put the negative lead to "pin 1" and strafe the rest with the positive lead;·if you get something to light then write it down and if not then move the negative lead to "pin 2" and strafe away, again...
If that turns up·a dead end·then start all over again with the positive lead on "pin 1" and strafe with the negative lead; continue on till you get results.
Post Edit -- I could make a youtube demo, but it'll cost you.· [noparse]:)[/noparse]
I did. [noparse]:)[/noparse] The 5X8 was relatively easy to do but the 14-seg, not so much.
I can get MOST of the segments to light. It is a common anode setup with pin 16 for digit1 and pin 11 for digit2. But there are a handful of segments that I just can't figure out by trial and error. The Dp being one of them.
Thanks for the friendly push PJ. Your description of how to look for the pinout what was exactly what I had done. Back to the testing board.
Mark
mirk handwrote
admire nth work
Mark
mirk handwrote
admire nth work
mirk handwrote
admire nth work
