loading image from external memory, getting prop to run it
Bill Henning
Ok, I tried search.parallax.com, but I could not find how to get the propeller to reset and run something I might load into it under the control of a large memory model loader [noparse]:)[/noparse]
Basically, I need to do a warm boot of the chip so that it will execute the image I load into the hub memory.
I have a vague memory that Chip posted how to do this over a year ago, but I could not find it.
A link would be most appreciated
www.mikronauts.com - a new blog about microcontrollers
' ' Start up oscillator and begin Spin program at $0010 ' (assumes EEPROM data already loaded into $0000-$7FFF) ' (assumes currently running RCFAST oscillator) ' (assumes this is COG 0 - gets rebooted) ' rdbyte address,#$0004 'if xtal/pll enabled, start up now and address,#$F8 '..while remaining in rcfast mode clkset address :delay djnz time_xtal,#:delay 'allow 20ms @20MHz for xtal/pll to settle rdbyte address,#$0004 'switch to selected clock clkset address coginit interpreter 'reboot cog with interpreter time_xtal long 20 * 20000 / 4 / 1 '20ms (@20MHz, 1 inst/loop) interpreter long $0001 << 18 + $3C01 << 4 + %0000 address res 1This is used in the various FemtoBasic versions and the Propeller OS.
