ImageCraft C Compiler Quick Status (part XIV)
Sorry, I can't locate the old thread..
Jan 30th status: we can now run small programs, including function calls
from C compiler through the asm, linker, and on the Propeller using LMM. We are in the process of tweaking the LMM kernels and API (which again will be published for anyone who want to tweak them further). Registers and local vars in COG RAM, and global vars in HUB RAM are all working as well. We are also adding basic support for COGNEW etc. so functions can be loaded into a different COG.
No date yet but we are working as fast as we can.
There is a number of you who have supported us in the back channel. *you know who you are*
Thank you so much. Every bits helps.
// richard
![smile.gif](http://forums.parallax.com/images/smilies/smile.gif)
// richard
This sounds good.
I'm excited to see how this turns out.
Share the knowledge: propeller.wikispaces.com
Lets make some music: www.andrewarsenault.com/hss
Can't wait!
No, just kidding.
Good to hear that you are making progress. But then, I didn't expect anything else.
Cerainly will buy it. I have some more Prop-developments in the queue.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
