sound sensor?
hello,
i have the basic stamp board listed here
http://www.parallax.com/Store/Education/KitsandBoards/tabid/182/CategoryID/67/List/0/SortField/0/catpageindex/1/Level/a/ProductID/313/Default.aspx
and i'm wondering if there is any sound sensor that i can find to use on this board.
im trying to hook up this sensor and get me a noise/sound reading in db.
There's a lot of good information on using sensors with Stamps here: www.emesystems.com
The "sound sensor" mentioned above provides a true/false signal if the sound exceeds a threshold. It would be possible for the Stamp to provide a voltage (using the PWM command ... see the Basic Manual) to set this threshold rather than have it set manually.
Post Edited (Mike Green) : 1/29/2008 7:54:18 PM GMT
This fellow set up a two channel (stereo) sensor; if you only need one, you could eliminate half the circuit. Apparently he had good results.
http://forums.parallax.com/showthread.php?p=572182
