help! trying to send a high from one parallax board to another
okay so are project is basically this ir sends signal to reciver that it sees its so
its
if irdetect = 1 then
high 15
endif
then we've connected a wire from pin 15 to another board in pin 6
does it need ground or sumthing? like
if in6 = 1 then
pulsout 13,650
endif
but its not recieving the high for pin6 to make it do what we want
like ive check the wire and used an led and the ir is sending the signal but
pin6 isnt doing anything...
its
high 15
endif
if in6 = 1 then
pulsout 13,650
endif
What's the "PULSOUT" supposed to be doing? If it's a BS2, "PULSOUT 13, 650" will give you a 325 uSec pulse -- that's AWFULLY small.
You may need an "INPUT IRDetect" line -- but probably that's the default...
instead of high 15 should it be low?
(board 1)
FOR bridge = 0 TO 220 'bridge opens
DEBUG DEC bridge 'displays amount of time it takes to open
PULSOUT 15,850
PAUSE 100 'waits
NEXT
(so in here the ir is sensed on different board sending the signal to pin 6)
(board 2)
DO
FREQOUT 6, 1, 38500
irdetect = IN5
DEBUG HOME, "irDetect = ", BIN1 irdetect
IF irdetect = 1 THEN 'ir detected
HIGH 15 'send high 15 signal to other parallax
ELSEIF irdetect = 0 THEN 'ir not detected
LOW 15 'send low 15 signal to other parallax
ENDIF
LOOP
(board 2)
IF IN6 = 1 THEN 'if pin 15 is high then
DEBUG BIN IN6 'displays if working
FOR bridge = 0 TO 220 'bridge closes
DEBUG DEC bridge 'displays amount of time it takes to close
PULSOUT 15, 650
PAUSE 100 'waits
NEXT
ELSEIF IN6 = 0 THEN 'if pin 15 is low then
DEBUG BIN IN15 'displays if working
END 'ends program
ENDIF
Post Edited By Moderator (Chris Savage (Parallax)) : 1/29/2008 9:57:27 PM GMT
as far as I understand you are not sending any signal thru IR led or detectors ! wright ?
Hope to help
Amaral
