Propeller keychain
A member of this forum, "computer guy" made a good looking sticker that he is selling here.
I like his design but the shipping costs are to much for me so I decided to make a keychain of it.
If you would like to make it at home, you need the following stuff:
- color printer
- 1 sheet paper for your printer
- a cartridge for your printer
- an empty keychain (you can open a used one)
- the attached image (little bit changed for 3x4 cm dimensions)
- a computer program to print a 3x4 cm image (or other dimensions for other keychains)
- scissors (or a paper cutter for the best result)
- color printer
Might even look better on photo-paper.
Of course you did both sides?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Well, it looks good on the picture anyway :P
Don't do both sides on normal paper,
print it twice because otherwise you will see it through the paper.
I did this on normal paper, but I could try photo paper.
I'm sure the result would be better that way.
See the attachment.
Post Edited (Robot Freak) : 1/30/2008 10:20:23 AM GMT
