stepper motor using serial to parallel convertor and objsect.
Has any one seen or heard of a object that will control a stepper motor using a serial to parallel ic? I wish to connect several stepper motors to my propeller and yet run them independently, so i am guessing that i would be able to run at least 5 or 6 per propeller.
Currently i am running a stepper motor using the object listed in the "stepping out" by nuts and volts. It works great i just want to free up some i/i pins and run a total of 18 stepper motors - independently.
http://download.siliconexpert.com/pdfs/2004/0629/semi_ap/1/roh/qd/bu2050f.pdf
I may be using this in a similiar app. since it requires such few pins.
Actually, my stepper's should be comming in any day now, and some Serial-Parallel IC's are on their way so I'll get started on the object. Collaboration is welcome.
Paul Baker
Yes I have since removed it. Sorry for the trouble, i wanted to experiment and did not like it either.
Back to the topic. If i can make it to my office tomorrow i will spend more time trying to address the coding. To me that seems to be the most difficult task.
Post Edited (grasshopper) : 1/28/2008 4:49:11 AM GMT
I ordered a 74LS164 serial to parallel IC's and a few more L293 driver IC's. They will be here on Thursday or Friday. My problem today has been trying to figure out how to get the current stepper object converted over to a serial object using only 2 I/O pins.
1 pin for Clock and the other to send out data in a serial fashion. Ill post a schematic some time soon.
See example in my I2C thread http://forums.parallax.com/showthread.php?p=703283
Post Edited (deSilva) : 1/28/2008 9:02:40 PM GMT
Pins 3,4,5,6,10 will be the parallel data out to the L293's I am hoping that with this configuration I can run 3 stepper motors using only 5 I/O pins on the propeller. Of course I will be wanting to go as high as say 15 stepper motors maybe using only 2 propeller IC's
DeSilva,
I will take a look at your example. Thanks
