Automated barbeque temperature control
Has anyone here tried to do the "Automated Barbeque Temperature Control" written by Barry Press from the book Geek House?
I really need help regarding this especially on the temperature probe... an error shows: error link 0002 No suitable main method found. (i attached the source code)
I hope someone could help me.. thanks
- Chino Magcalas
Philippines
- Chino Magcalas
Philippines
There must be one java file that has a static void main() routine.
That is your application program and that you can download to
the javelin. All other files used by the application program are
automatically linked.
regards peter
That class only has methods to read and convert temperature values.
You can add a main() to the class but then you need to know
what you like to do with the temperature values.
regards peter
I can send to you the whole procedure if its ok with you... I'm sorry for bothering you but i really need your help...
If you have all the hardware mentioned in the Geek article and have connected
all the hardware in the correct way, then you can program the javelin.
But first it is wise to create a folder c:\program files\parallax inc\javelin stamp ide\lib\stamp\BBQController
(and spell BBQController exactly as here) and put all the files into that folder.
Then place the line
package stamp.BBQController;
at the start of each·file and don't forget the ;
Close all files so they are saved.
Finally open file BBQController.java and you can download to the javelin.
regards peter
Post Edited (Peter Verkaik) : 1/27/2008 9:28:45 AM GMT
If i connect it to vdd the fan rotates slower bec it is regulated 5v... how am i supposed to maximize its speed if for example the temperature is lower
and it needs to warm up? I connected the gate of the transistor to the PWM (pin 8) is that correct?
The javelin pin that drives the fan with PWM goes indeed to the base of the transistor.
You don't need to regulate the fan speed, the program does that for you based
on temperature readings.
regards peter
i'm not familiar with the PWM so i dont know if its a pin or should i create a circuit for a PWM?
regards peter
About the temperature probe, do i need to remove the end part of it to reveal the wires and connect it to the circuit?
Thank you.
- Chino
P0 = uart output to write to lcd (see BBQLCD.java)
P1 = pwm output to control fan (see FAN.java) (not P8 as I mentioned before)
P8 = adc output for·temperature probe (see TemperatureProbe.java)
P9 = adc input to read temperature probe
Also, make sure all GND's from all devices are tied together.
You can see how the temperature probe is connected in figure 8-9.
regards peter
will the default program work even if i dont use the BPI 216 serial lcd as what the book recommends? I just bought a Hitachi hd44780 compatible lcd...
And also about the circuit of the actuator, what kind of diode(model) should i use?
I hope you dont mind my asking, its just that i'm having a hard time with the project...
thanks a lot i really appreciate it [noparse]:)[/noparse]
You can use attached class (you may need to change some method names).
The hd44780 uses pins 0-6 I believe, so they do not interfere with the adc,
but you may need to reassign the pwm output.
regards peter
since the com port of the javelin is 9pin, does it mean that i have to connect pins 0 to 6 for data then 1 for vss and vdd and contrast? a total of nine?
Now i'm starting to panic... if i wont be able to get this thing work, i'm going to repeat the subject...... I'm a graduating student of a University in the Philipiines...
please help me.... [noparse]:([/noparse]
manual, from start to end, before proceeding with this project.
Otherwise you will never get this project completed because I am sure you need
to tweak the ADC and possibly the PWM.
You can download the javelin user manual for free from here:
http://www.parallax.com/ProductInfo/Microcontrollers/JavelinDownlads/tabid/443/Default.aspx
regards peter
I'll still ask some questions when i dont understand something if you dont mind..
take care
chino
regards peter
