SPI would probably be easiest. I've had a PIC communicating with several AVRs using hardware SPI on the PIC and software SPI on the AVRs. It shouldn't be difficult with the SPI code in the Object Exchange.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
thanks Leon... what I wanting to do was hook my hydra to a pic Ethernet microcontroller andI would realy like to keep the hydras spi open for other things "like the sd max" so I was hopeing I could use the hydras hydra-net full duplex serial to hook to 2 togather....
I think I would use the pic16f688 or something with a built in serial rx/tx. I have two pics talking to each other with the baud rate set the same using the built in serial. I think you could get the serial prop programs to interface with a little work. I haven´t had the chance to try talking to the prop yet though.
I have a project that interfaces a Prop and a PIC16F871. PIC runs on 5v, Prop on 3.3v, so have a series resistor in Prop rx line. Running at 35714 baud; PIC has 5 MHz resonator.
Works fine; been running about a year with it now. No RS232 IC.
whare can I finde info on your project???? I'de love to see and learn more about it
Post Edited (phillip v) : 1/25/2008 5:03:30 PM GMT
Leon
Post Edited (Leon) : 1/25/2008 6:08:55 PM GMT
Harley Shanko
I've communicated some info to you off-forum via PM.
Harley Shanko
Leon
I think if I post anything more on this it will be in the HYDRA FORUM...
Post Edited (phillip v) : 1/25/2008 8:29:17 PM GMT
