pause commands
Hello all,.. Im still new to stamps, and trying to figure things out. I understand the pause command, but that it also has a "max" time you can set.(not to exceed 16 bits).·Is it possible to keep running a pause command over and over, so it can pause anywhere from 1 to 15 minutes? Not randomly though,·over the duration of maybe an hour, before looping back to the beginning?
Alternatively, you could wait for some time in seconds:
I was just thanking you in a post to a question about ways to destroy a stamp....So I could possibly indefinetely pause a program, without the stamp running out of memory, because it will loop on that command, for x amount of minutes, before its next function?
Is that correct?
