Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Manual vs. Compiler: A discrepancy regarding WR/NR in hub instructions. — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Phil Pilgrim (PhiPi)
23,514
2008-01-25 00:08
edited 2008-01-25 00:34
in
Propeller 1
Here's an error I got:
Here's what the manual says (p. 395):
There's nothing about this in the errata, so hopefully the manual is correct, and the superfluous error can be fixed in the compiler.
Phil
371 x 208
8K
495 x 152
10K
7.6K
10K
Mike Green
23,101
2008-01-25 00:24
edited 2008-01-25 00:24
Actually, the error message is correct. The difference between the RDLONG and WRLONG instructions is the WR bit. The manual is incorrect. If you were to use the NR effect, you would get a WRLONG instruction.
deSilva
2,967
2008-01-25 00:26
edited 2008-01-25 00:26
Alas, you are of luck, Phil: The manual is wrong... :-(
This issue comes up from time to time, and I commented on it also some months ago.
When you have a look at the binary representation of the opcodes you will find that NR is used to differenciate between WR and RD
Edit:
Damn! Mike was faster!
23,514
2008-01-25 00:34
Ach, so! I neglected to look at the code bits. Thanks, guys!
Sign In
Register
to comment.
Edit:
