Problem with pins 30/31?
I have an SD Card that works on my other breadboard prop. The breadboard version is on pins 16-19 and works fine. I've changed the pin layout up a little bit due to physical constraints, and soldered the molex SD socket to the protoboard now. I'm now using the following pins for the socket:
Data Out:··· 30
Data In:····· 0
Clock:········ 31
Chip Select: 1
I beleive pins 30 and 31 are used for the eeprom, and I think there may be a conflict going on which is giving me an error when I try to load a volume from the SD. Any thoughts?
Data Out:··· 30
Data In:····· 0
Clock:········ 31
Chip Select: 1
