Strange font in Editor Pane — Parallax Forums
GenRevGenRev Posts: 9
edited 2008-01-25 12:15 in Propeller 1
I installed the Propeller software on my computer.· Everything seems to work accordingly except that the font in the Editor Pane is compressed (see screen shot attachment).· Is there a way to change the font, or do you think the problem is with the computer?· I'm using an IBM with Windows XP Professional, version 2002.
As a side note, I installed the Stamp software to see if I would have the same font problem.· No issues with the Stamp software.
-GenRev
Post Edited (GenRev) : 1/24/2008 7:37:32 PM GMT
  • RaymanRayman Posts: 16,222
    edited 2008-01-24 19:38
    Try changing the size of the font and see if that helps... (I think mouse scroll up/down is the shortcut for that...)
  • ClemensClemens Posts: 236
    edited 2008-01-24 20:06
    look here, this seems to address the same problem:
    http://forums.parallax.com/showthread.php?p=642812
    The solution was to set the regional font to english, I guess.
    Also you should check, if the "propeller.ttf" font is installed in your systems font directory.
    Maybe you are using font managing software (like linotype font manager)?
  • GenRevGenRev Posts: 9
    Well, I checked the regional settings as suggested, clicked the pull-down menu to see all the options, decided it was set correctly, and closed all the windows without changing a thing.· I then reopened the Propeller software, and the font was correct.· Very strange, but it fixed the problem.· Thanks!
    -GenRev
