detecting humans
Hello all. I'm making a fairly large project which will be a sound chamber that has complete surround sound. I want it to be interactive as well. An example would be, there's a dissonant sound on one side of the chamber and if you move any part of your body towards it, it becomes more harmonious relative to the distance you are away from the sound. I've looked at several options but I can't find that perfect match. IR sensors can be finicky and won't detect ranges (at least the ones I've looked at), I can't use pings because they interfere with each other and are pretty poor at detecting people, and the chamber will be completely dark so I can't really use photoresistors. I've looked at hall effects/ Theramins for magnetic field detection but they also are tricky. I was hoping that there might be some other device that could detect the magnetic field that humans have around them. Also, the device doesn't have to be basic stamp as I will be using MAX/ MSP for most of the project functionality. But at this point I'll take what I can get. Thanks everyone for helping out.
~Ross
~Ross
EDIT: Actually you'd only need 2 ping sensors assuming the room is square. One on the N/S wall and one on the E/W wall. That would take your pings down to 10/second.
Post Edited (Jed) : 1/28/2008 9:48:26 PM GMT
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
Parallax PIR:·· http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/Level/a/ProductID/83/Default.aspx?SortField=ProductName%2cProductName
Acroname PIR:·· http://www.acroname.com/robotics/parts/R1-442-3.html
- Stephen
One of my projects on the backburner involves human detection / following. The idea is to use an ir temperature scanner for the sensor. I got the idea from my handheld, it can detect temperature differences over as little as a couple of inches within 15 ft. And it has a fairly quick response time, which would work for a scanner. Servo feedback would provide position location. The amount of scanners would depend on the accuracy needed, and the size of the room.
The problem is finding an oem module for a reasonable cost and simple interface. I found one at the link shown below, but only has a 1:1 lense which won't cut it for me, but may work for short distances. The spi interface could be a problem also.
Anyway, not a ready made solution or tested, but might be worth some research.
www.metrisinst.com/product-details?ID=42&sm_chart=0
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
For the speed of response and sensitivity (like detecting a moving hand, and EXACTLY how near or far it is) the ping would be most practical.
···· I have looked at thermal IR night vision cameras. I have to say, even the really cheap ones cost $1000.00.
Do you have a source for a cheaper one. I would be very interested.
Roborealm, is an interesting approach. Maybe the best solution. Correct me if I'm wrong, but Roborealm is object recognition software that runs on a PC.
There is a very new embedded object recognition hardware module from Recognetics that is showing great promise as well.
http://www.general-vision.com/publications/CogniMem_tech_intro.pdf
www.recognetics.com/download/DS_CM_EB1K.pdf
I wasn't suggesting that you use a a thermal IR camera. just a camera with night vision.
let me step back for a sec... roborealm has a filter that will block out every thing except skin tones, it can then give relative size of the skin toned area it recognizes, and based on the position in the image area, a distance/location. This is what I would recommended you use, if you weren't doing it in the dark, but in theory, you could create a "night vision skin filter" that would do the same thing.
This is further than I have been in roborelm but I believe that you could also compare a empty room picture with live video and have it determine whats different.....where the people are. so if you mounted a camera(s) on the ceiling it would be really easy to determine where people where.
Roborelm will send variable data via serial, so it's easy to receive info. I would just use an ordinary web cam in a lit room to get a feel for it. See if you think it will work in your application. They have a tutorial for people recognition.
as with most applications I think a combination of sensors will yield a greater accuracy.
DGSwaner
Post Edited (Dgswaner) : 1/28/2008 5:11:37 PM GMT
www.lpi.usra.edu/education/fieldtrips/2005/activities/ir_spectrum/ir_webcam.html
IR cameras are plentiful now for security, like this one with built in ir leds.
www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1857310
Expose it to the light and get it developed. You will now have completely blackened slides.
Cut out a piece of film the same size as the plastic filter you removed and put it in its place.
You now have a camera with an IR pass filter that block visible light.
You get some really errie looking images.
Post Edited (LilDi) : 1/28/2008 6:09:34 PM GMT
~Tnadz
