EepromNavagation program will not work
··· I am trying to do the EepromNavagation.bs2 program pg. 149 of the Robotics with the Boe-Bot book. I continue to get an Undefined Symbol error message highlighting "instruction" after the command "Select". Assuming I have not made any typos...is there something I'm missing? I did'nt find anything in the threads and PBasic 2.5 manual states an "expression" follows the "Select" command. Thanks in advance for any help.
············································································ a complete newby,
Are you using the following compiler directive in your program:
' {$PBASIC 2.5}
If not, you need to add that, as the SELECT command is only recognized in PBASIC 2.5 and beyond, and not before that compiler level.
Bruce Bates
There is no pleasure in having nothing to do;
the fun is in having lots to do, and not doing it!
····· Thanks for the suggestion...but I set· ' {$PBASIC 2.5} as a directive in·the program·and double checked it. Since this is a program in the "book" and published, I really believed more people would have ran into this problem.
··························································· Thanks for taking the time to reply,
······························································································· Dadar,
Thank you, that did the trick. I will dissect and compare your program and see where I erred.
Thanks Again,
Dadar,
Dave
Dave Andreae
Parallax Tech Support·
