Ways to damage a basic stamp — Parallax Forums
Matthew BurmeisterMatthew Burmeister Posts: 49
edited 2008-01-25 15:44 in BASIC Stamp
i would like to know all of the possible ways that could damage the basic stamp(s) so i don't make them when i get my BS2p. Also i have heard that you should start with the BS2. why is that?
print "connecter"
input "Which com"; com$ ' opens com
open com; com$ for read
close #com ' closes com
print "Com closed" ' displays text
end ' ends or stops the program
  • steve_bsteve_b Posts: 1,563
    edited 2008-01-23 13:32
    hmmmm.....lots of ways.....hammers, doorstops, boost chair (needs lots), bumper liner on a derby car, used as tiles in the bathroom, operated underwater.....
    Seriously though, a hammer will kill it! [noparse];)[/noparse]
    The BS2 is fairly rugged. You want to operated it dry, you don't want to run too much voltage/current in to it's pins. They have some protection, but too much current will kill those pins. Obviously shorting the pins is bad (power to a pin)....if you try to draw too much power from the stamp, you may end up "sagging" the power and the stamp would reset, not a big deal, but definately a pain!
    If you are using a Board of Education, you want to make sure you don't put too high a wall-wart else you'll probably kill the little regulator that changes that input voltage to 5Volts for the stamp.
    Not sure what you were really after....check your connections, at least, twice before turning things on. Watch when direct driving a relay; when the relay coil discharges, it could come back to the stamp pin....so look at a flyback diode on the relay or just make sure everything you connect is opto isolated!
    Cheers
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
  • ZootZoot Posts: 2,227
    edited 2008-01-23 13:39
    There a lots of ways to damage a Stamp -- but I will say that they are pretty dang rugged -- I've made many an error and had the Stamp come through unscathed. That said, here are my "easiest ways to damage a Stamp" (I'm sure others can add to this list):
    - putting too much voltage through the on-board Stamp regulator (like 17v from a wall-wart)
    - setting a pin to output when it should be an input and when there is no 220ohm resistor for protection on the pin
    - having large bypass caps on power rails that do not discharge when power is removed (i.e., you think everything is powered down, then you accidentally short the power rails with a screwdriver or the like)
    - drawing too much current through an entire bank of pins
    - connecting power to your board backwards
    - spilling a drink on a powered board
    Basically, I've found it's hard to damage a Stamp if you double-check your connections, put current limiting resistors on any output pins and on any input pins that may be connected to circuits that can sink/source a lot of current, and be careful in your work area. In short, I've found that USER ERROR is usually what does the dirty deed.
    As far as BSP vs. BS2 -- they are very similar and one is no easier than the other. The BSP is faster. The BSP contains additional commands (such as I2CIN and I2COUT) -- if you don't know what they are, don't use them and it's all the same. The BSP contains extra RAM space (scratch pad) -- again, if using the scratch pad is beyond your skills (at this point) don't use the feature and it'll be like having a very fast BS2.
  • Matthew BurmeisterMatthew Burmeister Posts: 49
    edited 2008-01-23 15:53
    Thanks... Now i know what not to do. i will be also be buying a BS2p because i will be wanting to connect a display later on
    print "connecter"
    input "Which com"; com$ ' displays text and lets user chose which com
    open com; com$ for read ' opens com
    ' JBASIC code www.justbasic.com
  • tweektweek Posts: 14
    edited 2008-01-25 06:32
    agrees with steve_b,.... opto-isolate. I learned that the hard way. But thanks to Mike Green, who posts here, told me about optoisolators. I havent made that mistake again, and my "death toll" stayed at one homework board. Thanks again Mike.
  • dandreaedandreae Posts: 1,375
    If you are unsure about your circuit, please ask questions before applying power.· We are more than willing to review your circuit.· You can send your questions to support@parallax.com.·
    Dave
    Dave Andreae
    Parallax Tech Support·
