Measure Voltage, output through p0-p7
I have problem with measuring voltage and showing the result per pin 0-7. the Voltage that i measured range from 0V until 2,5V.
pin 3 is always 5V, even when i give no input voltage.( ADCValue is about 125)
and when the ADCvalue is about 79, pin 1 is 5 V and also pin 3.
Anyone knows why?confused:
here is my program:
import stamp.core.*;
public class Distanz {
static int PORTA;
final static char CLS = '\u0010';
static int ADCValue;
static ADC voltMeasurer = new ADC(CPU.pin14, CPU.pin15);
public static void main() {
CPU.setOutput (CPU.pins[noparse][[/noparse]0] + CPU.pins+CPU.pins+CPU.pins+CPU.pins+CPU.pins+CPU.pins[noparse][[/noparse]6]+CPU.pins[noparse][[/noparse]7]);
while(true){
CPU.delay(5000);
ADCValue = voltMeasurer.value();
System.out.print(CLS);
System.out.println("ADC value is: ");
System.out.println(ADCValue);
if(ADCValue<=64)
CPU.writePin(CPU.pins,true);
CPU.writePin(CPU.pins,false);
else if((ADCValue>64) && (ADCValue<=128))
else
} // end while
} // end main
Adi Prasojo
Student of Mechatronics
Koblenz-Germany
here is my program:
static int PORTA;
while(true){
CPU.delay(5000);
if(ADCValue<=64)
else
} // end while
} // end main
Adi Prasojo
Koblenz-Germany
CPU.setOutput (CPU.pin0 | CPU.pin1 | CPU.pin2 | CPU.pin3 | CPU.pin4 | CPU.pin5 | CPU.pin6 | CPU.pin7);
Secondly, you must specify which pins in the if/else construct
CPU.writePin(CPU.pin0,true);
CPU.writePin(CPU.pin1,false);
You can use pins[noparse][[/noparse]x] but then you must specify x. If the pin number is constant, using pinX
requires less code.
regards peter
actually all i want to do is to measure a voltage from a sharp distance sensor GP2D120(output vary fom 0V until 2,5 V). and i would like to show the result in PORTA. do you or anyone know about this?
because I've tried to change the code just like you suggested. still I have the same problem(the output in Pin2 and 3 won't react according to the code).
to measure the voltage i use pin16 and pin15.
regards Adi
Adi Prasojo
Koblenz-Germany
maybe something else is wrong with your code.
regards peter
public class Distanz2 {
static int PORTA;
while(true)
CPU.delay(5000);
CPU.writePort(PORTA,(byte)ADCValue);
} // end while
} // end main
Adi Prasojo
Koblenz-Germany
i've tried to make it a bit simple. but it doesn't work too. the output (from System.out.println(ADCValue)) vary from 70 to 125. I had never been able to get output 0 when the sensor output voltage 0V.
Adi Prasojo
Koblenz-Germany
Post Edited (adi) : 1/24/2008 5:59:34 AM GMT
v
res(22K)
<p15
+---res(22K)---->p14
__+
---1uF
GND
Adi Prasojo
Koblenz-Germany
·· * Create a sigma-delta analog to digital converter virtual peripheral and
·· * start it running.
·· * @param inPin the pin to be used as an input by the converter.
·· * @param outPin the pin to be used as an output by the converter.
· public ADC(int inPin, int outPin) {
··· this.inPin = inPin;
··· this.outPin = outPin;
··· start();
You use in your code:
so pin14 is the input pin, pin15 is the output pin.
Your schematic shows them swapped.
So try this in your code:
static ADC voltMeasurer = new ADC(CPU.pin15, CPU.pin14);
regards peter
it looks like his output must be pulled down. I've used 10 kohm resistor to pull it down.
maybe if I use bigger pulled down resistor, would be better.
The schematic is attached.
regards Adi
this is the code:
// Program Listing 4.3 - ADC Test
//static int PORTA;
static ADC voltMeasurer = new ADC(CPU.pin9, CPU.pin8);
CPU.setOutput (CPU.pin0 + CPU.pin1 + CPU.pin2 + CPU.pin3 + CPU.pin4 + CPU.pin5 + CPU.pin6 + CPU.pin7);
while(true)
CPU.delay(5000);
CPU.writePort(CPU.PORTA,(byte)ADCValue);
} // end while
} // end main
} // end class declaration
Adi Prasojo
Koblenz-Germany
