As title....
I want to know how to control or communicate though the NetStart or other embedded systems, not though the compter.
Does it need many programs between them?
I have no idea with·it.
Thanks a lot.
can you provide a little more info on NetStart.. when I Google it I get all sorts of different companies and products didn't see an embedded system. have you looked at the Parallax P.I.N.K? it's an embedded web server, which doesn't require any "programs between".
if you want this to be on the Boe bot, (mobile) you'll need to find a wireless embedded system. or connect one via RF or other method. I'd find the system that meets your requirements as long as you can talk to it with serial or I2c or some other standard method, it shouldn't be to hard to get it working with your Boe Bot.
good luck
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
We write boe bot's program and perform it on the BS2 as a uausl way. But now I want to write nothing on the BS2 but on the embedded system. Is it possible?
good luck
DGSwaner
