serial graphic lcd
Tumbler
Can i use the BS2 or the BS2sx to control serial graphic lcd's?
if yes, wich one(s)
if yes, wich one(s)
If the LCD uses TTL serial you ready to go; if it uses RS-232 you'll need a level shifter. The latter is much less common.
These two are graphic based:
112 x 16 Serial Graphic VFD Display
120 x 32 Graphic LCD
and these are standard character based LCDs, but you can usually do custom characters to make little gfx:
Parallax 4x20 Serial LCD (Backlit)
4x20 Serial LCD with Keypad Interface
Parallax 2x16 Serial LCD (Backlit)
LCD Terminal AppMod
Vern
Post Edited (Vern) : 1/21/2008 10:07:19 PM GMT
