Interfacing Atari 2600 style Joystick
I am working on interfacing an Atari 2600 style joystick. I have been able to read values from the joystick. It basically fires 5v per direction pin (see http://pinouts.ru/Inputs/JoystickAtari2600_pinout.shtml·for the Atari pin-out).
I have put a 10k resistor between each of the joystick pins and the Prop pins. I have also got pin 7 direct to +5v and pin 8 direct·to ground (the same as the prop ground). I am however witnessing some strange behavior. Sometimes I am getting logical highs for Left when I push Forward. Then followed by the Forward etc. Sometimes if I press·forward, I will get 5 forwards in a·row.·This is strange. It is almost like it is getting some interference due to my interfacing. Does anyone know of a simple Atari 2600 joystick interface for the Prop? Anything obvious that I am doing wrong with my interfacing?
Post Edited (stamped) : 1/21/2008 8:35:27 AM GMT
dira[noparse][[/noparse]1..4] := %0 repeat waitcnt(clkfreq + cnt) if(ina[noparse][[/noparse]1] == 1) debug.cprintf(string("Forward"), 0, false) elseif(ina[noparse][[/noparse]2] == 1) debug.cprintf(string("Reverse"), 0, false) elseif(ina[noparse][[/noparse]3] == 1) debug.cprintf(string("Left"), 0, false) elseif(ina[noparse][[/noparse]4] == 1) debug.cprintf(string("Right"), 0, false)
Steven
have you seen my PropJoy at uController.com ?
as for help with your circuit, I'd have to see the circuit that you are using to connect. The joystick contains 5 switches, so it's just like interfacing 5 regular switches. You'll need pull ups (or downs) and some type of debouncing, either hardware or software.
The Propjoy uses a shift register, it takes a "snapshot" of the switch values, and you then shift the data out of the shift register to read the values of the switches. The resulting output is a 8 bit value, reading individual bits will reveal which switches are depressed.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Brian
SD card Adapter
There's details in the Cookbook, and in the Object Exchange.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Just duplicate it 5 times and you're in business.
OBC
OBC; thanks for the tip in the Cookbook. I will give it a shot and post the results.
With regards to Brian's UController parts; I have already bought a heap of parts (SD Card, Ethernet, Servo Controller, SpinStudio, LCD board etc) from Brian but have not had a chance to solder them yet. I just noticed the joystick part a few days ago. I do not have time to wait on the shipping, so I will try to do a temporary solution using the de-bounce..
Note; I have ordered one of Brians PropJoy's (excited about 4 pins for two sticks - authentic tank control!). That said, I would like to work out why this circuit is not working to plan. Any suggestions are appreciated!
