Does programming the Propeller work with Parallels Desktop?
I have an Macbook Pro 2.16GHZ (Intel Mac) running Leopard 10.5.1. I·am using Parallels desktop 3.0 build 5584 to run an Windows·XP virtual machine image file. I have an education kit and a demo board, neither of which am I able to program with the Propeller tool.·If I select IDENTIFY HARDWARE, I get a message 'Propeller chip version 1 found on com6'. But if I choose to LOAD RAM or LOAD EEPROM i get the message 'No Propeller chip found on any Com port. Scanned com6.' Per a post I found on this forum I have gone into the device manager in·Windows and set the comm port latency to 1, but no luck.·Does anyone have any·suggestions or information on the subject that would be useful? Thanks
Make sure you have the proper drivers (and the latest) installed for the FTDI chipset. I have both Mac and Windows drivers although Parallels uses only the Windows driver as far as I can tell.
Tried your suggestions without success. Is there a newer FTDI driver than the one that gets installed with the Propeller Tool ver 1.05.8? I don't do any FTDI com work on the MAC side, so I don't know what driver I would have installed for MAC (if it matters). I also have 2GB of ram, but I have manually set the allocated ram for my Virtual Machine to 768MB. I have read on the Parallels forum that some people have found that the amount of ram allocated for the VM, larger or smaller, can sometimes adversely affect performance. How much ram is your VM using? Also, do you enable Parallels Virtual Memory Preallocation?
My VM is set for only 512MB and the VM preallocation is off.
I've been using it for a few months with Parallels on Tiger running Windows XP.
At first when I updated the 2.0.0.0 driver, which I believe was installed with Propeller Tool 1.05.8, to 2.2.4.0 the programmer started to work, but half way through failed and after that it never tried to worked again. I've looked at the Task Manager processes pane and have no CPU hogs running. CPU usage is at 1 to 3%. I shut off my virus software and microsoft update. I've set Parallels USB preference to connect all usb devices to guest OS.
Post Edited (Marc Gebauer) : 1/22/2008 8:32:04 PM GMT
1) Remove and completely reinstall a freshly downloaded Propeller Tool (V 1.06) and its USB driver.
2) Reinstall Windows in a fresh VM and reinstall the Propeller Tool and its USB driver.
I've tried a variety of memory allocations and Un-installing/Reinstalling the FTDI driver/Propeller Tool did not help. I created a second Windows XP virtual machine upon which I·installed the Propeller Tool·and it works. Yay!·Since I can share files between both of my virtual machines,·I have no problem·using a second VM for the Propeller Tool. If I ever figure out how to fix my original VM,·I'll post the fix here.
Is the serial protocol available somewhere? -Chuck-
Look at the "sticky" threads at the beginning of the Propeller Forum for Graham Stabler's Good Thread Index and you'll
find links to these.
Steven
