Velocity
Can anyone think of a clever way to read velocity accurately? I am trying to make a velocity meter by using a small dc motor to generate voltage such as in the link:
http://www.amazon.com/gp/product/B0002WZRKE/ref=s9_asin_title_1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0W3GACJDGV7ZT0ZT707D&pf_rd_t=101&pf_rd_p=278240301&pf_rd_i=507846
I have the two leads of the motor connected to a voltage meter so I can gauge the velocity by the output voltage, but I have no idea what the actual velocity is in terms of FPM (feet per minute). So what I am interested in is a base point such as:
.5V = 10 FPM
1.0V = 17FPM
2.0 = 32 FPM
etc
Once I have those values, I can then interpolate the rest of the missing numbers.
I am open to any ideas including using a differential pressure gauge to obtain a pressure reading, which can be converted into velocity. Or maybe even using the Parallax Flexiforce pressure sensor to gauge the Force by the air. Then using
F = mass flow rate x Velocity
to solve for velocity if I can figure out what the affected area on the Flexiforce sensor is.
Any ideas?
.5V = 10 FPM
1.0V = 17FPM
2.0 = 32 FPM
etc
Any ideas?
here is a pdf for something simmilar... hope it helps
http://www.basicmicro.com/downloads/docs/RRPM.pdf
http://www.parallax.com/Resources/NutsVoltsColumns/tabid/272/Default.aspx
http://www.parallax.com/Portals/0/Downloads/docs/prod/sic/SmartSensors-v1.0.pdf
Page 65 of the pdf
I do suppose by knowing the rpms I could calculate the tip velocity with
v = wr where w is the angular velocity,v is velocity, and r is the radius.
Has anyone ever tried to use the flexiforce sensor? Could I set the sensor up to apply P = F/A where
P = pressure
F = force
A = area
Then once I have the Force (F), solve for velocity by F = mdot*V where
F = force (from above)
mdot = mass flow rate of air (1/density of air)
V = unknown
Thank you for your suggestions.
