RF 27981 Receiver and using RSSI
I am trying to actually use the RSSI pin on the RF receiver module #27981. There are few code examples, and few specs. I have set up the standard ADC converter from the manual and this seems to work okay in the 5 Volt range (though I seem to have a bias in the circuit). Anyway, has anyone out there actually used this pin? Any hints ? What is the expected voltage range ?
Thanks for any help
Vince L.
Thanks for any help
Vince L.
with a multimeter. Measure the voltage with your transmitter off (no signal),
and with your transmitter very close by and switched on (maximum signal).
regards peter
See attached document.
regards peter
