PSC with continuous servos — Parallax Forums
explodinggreenexplodinggreen Posts: 1
edited 2008-01-18 07:07 in BASIC Stamp
When I use the serial PSC with continuously rotating servos, they move slowly when the PSC is turned on and connected to the BOE.
Is there a simpler way to stop their rotation than finding the neutral PW value for each motor?
  • ZootZoot Posts: 2,227
    No, not really (at least not with the PSC).
    If your continuous rotation servos have a screw-adjustable pot for "tuning" the neutral point, that would be easiest. If you can not adjust the neutral/center point on the servo itself, you will need the host that is controlling the PSC to send your calibrated "neutral" pulsewidths upon startup.
    With a "roll-your-own" controller (say on an SX) you could program your calibrated centers for each servo to be used as the "neutral" output when receiving a 1.5ms position command.
