I know several customers have worked towards this, but I don't know if any have completed it. There is an object in the object exchange which interfaces with GPS ( http://obex.parallax.com/objects/225/·), it's not our GPS module, but the serial communication is pretty much standardized so you may have luck with it.
Do you have the "Calendar" object that is called on?
Cal : "Calendar"
OBC
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki (Got the Knowledge? Got a Moment? Add something today!)
These files reaaally need to be in the obex. Is Dr. Boone around to put them up?
Also in the main object, the documentations says to use P0 for serial io but down in the code it is set to 7. This needs to be corrected before it is posted and probably should be set to a constant.
Thanks Dr. Boone for the code - its saved me a day or so when hours are in short supply!
Wow. I just hooked up the Parallax GPS to a Propeller for my first time, and set up that smart mode object with some code to read it and display it on an LCD. Works perfectly.
I'm so impressed by all of this. It's so easy to get the Propeller to do interesting things.
people currently workng on it
http://forums.parallax.com/showthread.php?p=695540
someone who has used GPS in thier project (don't know if it's Parallax GPS or not, but he says it's like ours):
http://forums.parallax.com/showthread.php?p=662235
Paul Baker
Post Edited (Paul Baker (Parallax)) : 1/18/2008 2:07:10 AM GMT
· I haven't been able to find the a smart mode version, could you direct me to it (or post it)?·
JasonE
Wow, that's perfect. The author should post that in the object exchange.
Thank you very much!!!
-JasonE
OBC
·Thanks again, I just fired up my GPS module for the first time this weekend.· The code you posted works great!
It is very easy to use.
Good Luck,
Kevin
