Who can make this micro PCB ?
I know I know, the number of post asking for a board house recomendation is staggering...
but mine is special (not).
I need to have a PCB made but it is REALLY small.
.4"· x· .54"
The thin guage board, I think it's called .8mm or .03" ??
Small trace width·.4mm.
2 layer.
The first few I contacted couldn't do it.
Any recomendations on who might be up to this very small job?
.4"· x· .54"
2 layer.
Those requirements are on the extreme end of the spectrum.
Don't take this the wrong way, but I do not think you will find anyone who will make that board without a whole panel being made. (panel containing about 100 of those in one sheet)
The size is not bad if you have a panel made, and the material is not that bad either.
If you not opposed to having a panel made in China (whole panel not just one board) and your requirements are correct, you could have Gold Phoenix make the panel.
http://www.goldphoenixpcb.biz/special_price.php
The job is not small....just your board. No one that I know of would make just one board that small. It's just not feasible.
This is all based on the fact that the trace width is truly .4mm which is not that small. (about 15mils)
If your looking for 0.04mm ....that is a totally different story....and·practically impossible without a laser.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
Paul Baker
Also.....I and a lot of my associates have done business with Gold Phoenix....they are a pretty good company.
James L
James L
Partner/Designer
I might be able to make it on my LPKF mill.
0.4"x0.54" no problem
0.031" no problem.
0.015" traces no problem (I assume you have 0.015" spacing or there abouts)
If you could send a picture of the board I could let you know if I can do it.
Bean.
www.iElectronicDesigns.com
For about 100 dollars. Thats a lot of cutting.
Yes...it is a lot of cutting.....but that is what they do.
Remember.....it does take some time to get the boards back from Gold Phoenix.....
James L
James L
Partner/Designer
This means they will panelize it for you and score both sides of the board to deliniate the individual boards. If you take the board and align the score along a hard edge, place even pressure along the board and snap the row off, repeat this to seperate all the individual boards.
Paul Baker
Mind if I ask what the board is for?
Whit+
A couple of our small circuit board designs for sensor probes end up in the form of 0.4" diiameter circles. The boards come as multi-up scored strips, which we rough cut into multigons, and then put them on a spindle against a fine sanding disk. That effectively spins them down to size amd a very nice circle. I have a tooling hole fabbed in the center for the spindle. Those boards have parts (MSOP, SC70 & 0603) on both sides and fine wire leads.
You can ask most fabricators for "mouse bites". Those are rows of 0.020 holes that can help in separating panels. They are quite often used on the tabs that connect tab-routed panels.
Tracy Allen
www.emesystems.com
The boards are Square. I will cut them out a bit oversized and sand to fit. Some of the traces needed to be very close to the edge, and I was afraid of the v-score not lining up perfectly. Since I have a machine shop it really won't take that long to cut out and sand 20 of these buggers.
Besides I couldn't seem to get the Gold Phoenix to understand what I wanted, so I figured it wasn’t worth it being done wrong.
