Using a DC Motor dynamo (generator) to power bs1
Does anyone have any experience powering a Basic Stamp 1 (or 2) from a dynamo. I am spinning a DC motor and my meter reads a voltage of about 20 volts. I send this through a 12 volt voltage regulator and onto a BS1 and circuit. Any advice on the matter or know anywhere specific to look for information?
Blake
Blake
If this were a real world application, such as having a bicycle tire driving the dynamo, here is what I'd do. I'd use rechargable NiCad batteries to power the PBASIC Stamp. Then I'd use the dynamo to re-charge the batteries. This way, if you're standing still at a stop light, the micro-controller board will still be powered. The battery depletion from that wait will soon be replenished as you begin moving again, when the dynamo recharges the batteries.
Just be careful to put some sort of limiting system on the charging circuit so the batteries don't become overcharged. Another benefit to a system like this is that the PBASIC Stamp will never see the inconsistant voltage which varies as much as the output of the dynamo will. The voltage output of the dynamo will often vary with speed.
The last benefit of this system is that the amperage capacity of the batteries, and not the amperage capacity of the dynamo, is the limiting ampacity of the entire system. Thus, a small dynamo could power a system which provides more short term amperage than the dynamo is instaneously able to produce.
Bruce Bates
Veni, Vidi, Velcro! - I came, I saw, I stuck around!
Blake
If you use a diode in series between the dynamo and the input filter capacitor, it will prevent the capacitor from discharging through the dynamo when it slows down. This will allow the capacitor to power your BS1 for a while after the dynamo slows down.
In addition to Mike's fine advice, here's what actually going to happen, so we'll let you be the judge. The PBASIC Stamp will go into RESET mode as soon as the voltage drops below the "brown-out" point. This is NOT when the dynamo stops producing power, but when the voltage drops below something like 4.5 VDC (check this voltage for accuracy).
Once in RESET mode, it will remain in RESET mode unless or until the voltage is increased to a proper operational voltage, or when the voltage drops dead altogether. In either case, of being in RESET, or the voltage completely dying, the Stamp will no longer function at that point. When the Stamp begins operation again, it will start at the beginning of the program once again.
Bruce Bates
Blake
Note that 0.47uF capacitors usually are not polarized. You should also have a capacitor across the output of the regulator. Check the datasheet for the device for the recommended value. The diode should be a 50V unit at least.
