Is HP5160x2.SXB the most recent version; same as pre-installed SX code on Seria
Zoot
I want to tweak the driver code on one of my inkjet boards, and want to make sure that this is the code that was pre-loaded on the on-board SX (so that I can reinstall it when/if I goof on my own changes). This code and accompanying documentation were downloaded from the Parallax product page.
Also, I think there is a typo in the remarks at the top of the program, which describe a 32 byte text buffer. Inkjet Board documentation says 64 bytes, and the SX/B code uses a 64 byte buffer and max count.
See this thread http://forums.parallax.com/showthread.php?p=702094 if you're curious about (small) changes I'm going to make.
' ========================================================================= ' ' File...... HP5160x2.SXB ' Purpose... Simple Driver for HP 5160x Inkjet Cartridge ' Author.... Jon Williams, Applications Engineer ' Parallax, Inc. -- Copyright (c) 2005, All Rights Reserved ' E-mail.... support@parallax.com ' Started... 11 OCT 2005 ' Updated... 08 NOV 2005 ' ' ========================================================================= 'TYPO? ' To print text: <STX>Some text<ETX> ' -- Note that the text buffer is 32 bytes; printing will start as soon ' as 32 characters are received and others will be ignored.
