WiPort - Anyone used it before
Just wondering if anyone has used the WiPort or WIPort NR with the propeller before.
WiPort - www.lantronix.com/device-networking/embedded-device-servers/wiport.html
WiPort NR - www.lantronix.com/device-networking/embedded-device-servers/wiport-nr.html
Thank you![smile.gif](http://forums.parallax.com/images/smilies/smile.gif)
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Sticker
Thank you
I seem to remember someone also mentioning heat from it (but that might have been something else).
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
I will be powering from power supply so no power problems.
Might have to heat sink it then. Will have to see.
Thank you simonl
http://forums.parallax.com/showthread.php?p=621718
http://forums.parallax.com/showthread.php?p=658540
They imply that it can be done, so I will proceed. Might even try to write a driver, whilst learning assembly.
Hope they aren't to expensive.
Hope this helps..
John Twomey
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 1/15/2008 5:27:25 PM GMT
Thank you, I think I will use the WiPort, I like the features and the look.
Interesting regulator, I like the 1.4A without heatsink.
It has three pins TXD, RXD and RTS.
When connecting it up to the prop can I just connect it straight through or would I need a Xcvr.
If I don't need a Xcvr would I need to use pullups at least.
Thank you
Post Edited (computer guy) : 2/4/2008 8:29:39 AM GMT
Steven
That makes me happy.
Less components means less space taken up on the pcb.
