Need help with ASM code — Parallax Forums
richaj45richaj45 Posts: 179
edited 2008-01-18 19:44 in General Discussion
I need help to get the best asm code for the following:
1) Declare 12-bit label values stored in program memory.
2) Index into the table of values with a 8-bit number.
3) Read the 12-bit value with iread.
4) Jump to the 12-bit value as a program memory location and start
execution.
I am new to the SX ASM so could i get help in making this as fast as possible.
cheers,
rich
[noparse][[/noparse]edit] Rich, I added a subject to your post. Bean.
Post Edited By Moderator (Bean (Hitt Consulting)) : 1/15/2008 12:50:31 PM GMT
  • BeanBean Posts: 8,129
    edited 2008-01-15 13:52
    richaj45 said...
    Rich,
    · Do you want a quick reply ? Or do you want the CODE to execute quickly ?
    · Here is some output from SX/B to do it. I'm sure it not the as fast as it could be.
        55  =0000000D       temp1         EQU  0x0D          ;temp1   VAR BYTE
        56
        57  =0000000E       tempW         EQU  0x0E          ;tempW   VAR WORD
        58  =0000000E       tempW_LSB     EQU  tempW
        59  =0000000F       tempW_MSB     EQU  tempW+1
        60
        61
        62  07FF  0A00      RESET __PROGSTART                ;PROGRAM Start NOSTARTUP
        63  =00000000       __PROGSTART:
        64  0000  0CF7        MOV FSR,#__TRISA
            0001  0024
        65  0002  0CFF        MOV IND,#255
            0003  0020
        66  0004  02A4        INC FSR
        67  0005  0020        MOV IND,W
        68  0006  02A4        INC FSR
        69  0007  0020        MOV IND,W
        70  0008  0064        CLR FSR
        71  0009  0010        JMP @Start
            000A  0A0D
        72  =0000000D         ORG $+2  ; FOR DEBUGGER
        73
        74
        75  =0000000D       Start:                           ;Start:
        76
        77  000D  0C02        MOV temp1,#2                   ;  temp1 = 2
            000E  002D
        78
        79
        80  000F  0403        CLC                            ;  temp1 = temp1 << 1
        81  0010  036D        RL temp1
        82
        83  0011  0C33        MOV __PARAM1,#Table & 255      ;  READ Table + temp1, tempW
            0012  0028
        84  0013  0C00        MOV __PARAM2,#Table >> 8
            0014  0029
        85  0015  020D        ADD __PARAM1,temp1
            0016  01E8
        86  0017  0603        ADDB __PARAM2,C
            0018  02A9
        87  0019  0209        MOV M,__PARAM2
            001A  0043
        88  001B  0208        MOV W,__PARAM1
        89  001C  0041        IREAD
        90  001D  002E        MOV tempW_LSB,W
        91  001E  02A8        INC __PARAM1
        92  001F  0643        ADDB __PARAM2,Z
            0020  02A9
        93  0021  0209        MOV M,__PARAM2
            0022  0043
        94  0023  0208        MOV W,__PARAM1
        95  0024  0041        IREAD
        96  0025  002F        MOV tempW_MSB,W
        97
        98  0026  0403        CLC                            ;  temp1 = temp1 >> 1
        99  0027  032D        RR temp1
       100
       101
       102  0028  020F        MOV M,tempW_MSB                ;  READ tempW, temp1
            0029  0043
       103  002A  020E        MOV W,tempW_LSB
       104  002B  0041        IREAD
       105  002C  002D        MOV temp1,W
       106
       107
       108  002D  0010        JMP @$                         ;END
            002E  0A2D
       109
       110
       111  =0000002F       DATA0:                           ;DATA0:
       112
       113  002F  0080        DW 128                         ;  DATA 128
       114
       115  =00000030       DATA1:                           ;DATA1:
       116
       117  0030  0081        DW 129                         ;  DATA 129
       118
       119  =00000031       DATA2:                           ;DATA2:
       120
       121  0031  0082        DW 130                         ;  DATA 130
       122
       123  =00000032       DATA3:                           ;DATA3:
       124
       125  0032  0083        DW 131                         ;  DATA 131
       126
       127
       128  =00000033       Table:                           ;Table:
       129
       130  0033  002F        DW (DATA0 & 255),(DATA0 >> 8),(DATA1 & 255),(DATA1 >> 8),(DATA2 & 255),(DATA2 >> 8),(DATA3 & 255),(DATA3 >> 8) ;  DATA DATA0, DATA1, DATA2, DATA3
            0034  0000 0030 0000 0031
            0038  0000 0032 0000
       131
    Bean.
    www.iElectronicDesigns.com
    Post Edited (Bean (Hitt Consulting)) : 1/15/2008 1:58:11 PM GMT
  • richaj45richaj45 Posts: 179
    edited 2008-01-15 16:26
    I don't need a quick reply but i do need the asm to run as fast as possible.
    cheers,
    rich
  • BillXGSBillXGS Posts: 6
    edited 2008-01-18 06:20
    I hang around the XGameStation board and lurk over here once in awhile,
    but found this programming challenge too tasty to resist registering
    just to answer.
    A general way of doing a jump table with an SX in not easy.
    But if you can live with a few constraints, it can be done fairly
    efficiently.
    1. You are limited to no more than 126 entries in your table
    2. You must allocate a scratch file register; I will call it Scratch
    ; Call with index in W
    Dispatch:
    mov Scratch,W ; Double the index
    add W,Scratch
    add PC,W ; Jump to vector
    page Entry0
    jmp Entry0
    page Entry1
    jmp Entry1
    page Entry2
    jmp Entry2
    Bill
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2008-01-18 08:40
    Bill,
    the code can be modified to avoid the Scratch register:
    mov !option, #%01011111 ; clear option.7 to map w into 01h
    Dispatch
    clc
    rl wreg ; Note: you must use "wreg", SASM will generate wrong code when you use "w" here
    add pc, w
    page Entry0
    jmp Entry0
    As long as most jump targets are located in the same page where the dispatcher is located, you can even simplify the code but still handle cases where some code is outside the current page:
    Dispatch
    add pc, w
    jmp Entry0
    jmp Entry1
    jmp Entry2
    Entry0
    Entry1
    Entry2 ; This is an intermediate target - the remaining code for Entry2 is located in another page
    page _Entry2
    jmp _Entry2
    Greetings from Germany,
    G
    edited 2008-01-18 11:54
    Gnther,
    True, but he did not specific which particular processor he was using. That option is not available with the SX-48 or SX-52. Or he may need access to the RTCC register.
    edited 2008-01-18 12:10
    If the index was already in a file register instead of W, then just do this:
    mov W,Index
    add W,Index
    add PC,W
    edited 2008-01-18 12:27
    BillXGS said...
    Gnther,
    Welcome Bill,
    · The SX48 and SX52 also allow using WREG by setting the bit in the OPTION registers. Just for the book.
    Bean.
    edited 2008-01-18 17:20
    Thank you much for the great response.
    At first thought, i would have looked at using the iread instruction so a jump table would not be needed.
    When is the iread instruction used.
    cheers,
    rich
  • James NewtonJames Newton Posts: 329
    http://www.sxlist.com/techref/ubicom/lib/mem/tables_sx.htm explains it all.
    bitnum2mask
    ;load lower byte of address plus index
    mov temp, W ;store index
    mov W, #table_start && $FF ;w = lower byte of table start address
    add W, temp ;add index to w
    mov M, #table_start >> 8 ;load higher address of table
    snb C
    mov M, #table_start >> 8 + 1 ;correct if carry
    IREAD ;read table to M:W
    mov M, #$0F ;restore MODE to default
    table_start
    dw 1, 2, 4, 8, 16, 32, 64, 128
    Better ways are available with macros:
    http://www.sxlist.com/techref/ubicom/keymacs.src·
    The LookupW macro conditionally·leaves out the snb and second mov when they are not needed.
    The GotoW macro automatically compiles the most efficient possible jump table (not IREAD) given some supporting defines and sub macros. It's complicated to understand/explain, but it works very easily and always produces the best possible code.
    There are also IF / THEN / ELSE·/ CASE and all that macros.. not that anyone would bother...
    James Newton, Host of SXList.com
    james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
