USB to Serial Adapter Problem
I just got a BASIC Stamp Homework Board and i have it hooked up to my computer with a USB to Serial Adapter and when try to identify in the BASIC Stamp editor it doesn't detect the Homework Board. Is there any software I need to install? If some one could point me in the right direction and help a noob out that would be great.
Jias
Jias
If it's installed properly, even if your board has no power, the "loopback" and "echo" tests should pass.
parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/Level/a/ProductID/379/Default.aspx?SortField=ProductName%2cProductName
instead of just a random USB Serial Adapter?
1) The default USB to serial adapter drivers in Windows may not work properly. You have to install the manufacturer's drivers.
2) Not all USB to serial adapters will work with the Stamps or the Propeller or the SX processors. The main issue is that many USB to serial adapters only provide the transmit data and receive data signals and do not provide the control lines (DTR / RTS / RI / CTS / DSR). Parallax's products require that DTR work.
What brand is your adapter? Some, such as Belkin do not work properly with our hardware. You would only install our driver if you’re using our USB to Serial adapter based on the FT232 IC.
www.emtcompany.com/products/adapters/dxubdb9-usb-to-serial-db9-adapter-cable.htm?gclid=CKz9lInM9pACFQJ-lgodKhUU2g
It didn't come with a disc or anything to install. Would it work?
Without the correct drivers for the device there’s no way to determine if it will work properly. Perhaps you can return it and purchase a known working unit, such as our 28031 for under $20.00. Take care.
I've used FTDI's adapters, Parallax's adapters, and Keyspan's High Speed Serial Adapter with the Mac OS and Windows with the current manufacturer's drivers and all have worked fine.
