Capacitive switch circuit
·I am·testing·an idea of using a capacitor RC circuit for a 30 minute timer to wake up a processor. Testing the voltage leakage using a .01uf capacitor with no resistor to allow the capacitor to discharge only through the input pin is unknown right now as it is over 900 seconds as·I write this. However a new idea I got while touching the leads and thus stopping the timer (discharging the .01 cap) i realized a simple one capacitor touch switch can be made. When you touch the leads the pin can not hold a charge for more than a second, perhaps as little as a few miliseconds, not sure yet.
To use it as a capacitive switch simply charge the cap, wait 1/2 second and test if it is high. If not then someone has their finger on the leads. If it is high, at some point it will go low when the cap finally discharges, simply charge it up again and test if it holds a charge.
I looked at about 4 schematics·that used·all kinds of components used for capacitive switches but I have yet to see one with only 1 capacitor used for the circuit so·I thought it was pretty cool, so give it a try.
I know it is not really a capacitive switch but·I don't know what to call it.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 1/13/2008 7:38:34 AM GMT
You could make a touchpad with two contacts or interdigitated contacts with one side to the input pin and the other side to ground, so that the finger would bridge the gap reliably. But do include a resistor over to the pin to protect the pin from static discharge. And the contacts would have to remain pretty clean, I think. Moisture or gunk could effectively short circuit the path.
I've use that sort of circuit and PBASIC with things like rain gages. www.emesys.com/OWL2rain.htm. The capacitor acts as a short term memory for infrequent, short events.
Tracy Allen
www.emesystems.com
I've seen a variant of this technique used in a cheap electronic fish scale. In this case the coupling was mediated by a capacitive load cell which sandwiched a (barely) moving central sending plate between two outside receiving plates. The two received signals were sampled differentially to determine the weight of the suspended fish.
With an ADC, I agree, it could become very sensitive. I think that is the principle behind "capacitance to digital converters" like the AD7143. The excitation is applied to one half of the button or keypad slider or wheel, and the capacitive elements each go to an ADC pin to be read in round robin fashion. Touch disturbs the field and the chip decodes the point where the touch occurred. The chip makes it pretty simple, and the hardest part it takes care of is the self=calibration and adaptation to changing environment. One chip, some patterns on a PCB, and the microcontroller, that's all it takes for some fancy i/o.
The qprox devices use a slightly different principle, where the external capacitance itself becomes part of a switched capacitor ADC.
Tracy Allen
www.emesystems.com
