how to get label in rept to work — Parallax Forums
msmirbmsmirb Posts: 4
edited 2008-01-16 07:42 in General Discussion
I try to assemble the following:
rept 16
···· jmp MyLabel%
···· nop
MyLabel%
endr
but it says label already defined. Ive tried a few combinations but can't get anything to work.
I hoped it would assemble as:
··· jmp MyLabel0
···· nop
MyLabel0··
···· jmp MyLabel1
···· nop
MyLabel1
etc...
  • PJMontyPJMonty Posts: 983
    edited 2008-01-15 02:49
    Msmirb,
    Given that your desired resulting code...
    jmp MyLabel0
         nop
    MyLabel0
         jmp MyLabel1
         nop
    MyLabel1
    etc, etc
    ...is identical to this:
    jmp $ + 1
    nop
    jmp $ + 1
    nop
    jmp $ + 1
    etc, etc
    ...you could skip the whole label stuff. What exactly is the point of this code. Your "nop" could be any single byte of gibberish since it will never get executed anyway. In addition, since you apparently need only 16 copies of this code, you could cut and paste it in about 30 seconds rather than trying to figure out how to get a macro to do it.
    PeterM
  • msmirbmsmirb Posts: 4
    edited 2008-01-15 03:01
    Thanks Peter,
    Sorry it was only an example for clarity, my real code does much more and I didn't want to manually work the nn in $+nn since this is prone to error if I alter the code. Copying it 16 times doesn't help readability and I then have to change 16 places if I alter the code.· If I have to I will do one of these but I would have thought there must be a proper solution as in other compilers, I just can't find it in the documentation.
    Best regards
    Mark
  • James NewtonJames Newton Posts: 329
    edited 2008-01-15 03:25
    Time for the naked ugly truth as I know it: The macro section in SASM has a few strange and interesting bugs. The ones I've found have been reported years ago, but the people who originally wrote the code (back in Scenix days) apparently aren't around and what they left behind is, according to the people who have seen it, a mess that no human could hope to correct without introducing more bugs than they fixed. Peter did fix some bugs years ago, much to his credit.
    Having said that, I've been able to do some fairly cool things with macros in the past:
    http://www.sxlist.com/techref/new/letter/news0403.htm starts from the beginning, but may point out some things that will help reguarding local and global scope in macro labels. E.g. try local variables rather than global.
    http://www.sxlist.com/techref/ubicom/inst/macro.htm links to that and other interesting macro related things.
    Let us know what you find.
    James Newton, Host of SXList.com
    james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
    edited 2008-01-15 05:53
    Mark,
    The problem is that the assembler gives up on pass 1 because it hasn't expanded the "%" into a number yet. Because of the unexpanded "%", SASM looks in the symbol table to verify that there is no other symbols with the same name, finds the exact same symbol and flags it as an error. This is one of those, "Is it a bug or a feature?" kind of situations. You want the assembler to prevent duplaictae names (feature), but you want it to recognize that the "%" means you have to wait until pass two to figure out if there is a duplicate (bug ).
    The fix requires changes to the SASM source code. I'm pretty sure there's no way to "trick" the assembler into doing what you want it to do.
    PeterM
    edited 2008-01-15 06:04
    Mark,
    I played with it a bit more and realized it's really a feature and not a bug. The problem is that the percent sign is a perfectly legitimate character to use in a label. For example, a label like this...
    L%a%b%b%e%l%
    ...is just a label. For SASM to handle it differently inside a repeat could have some unintended side effects. Specifically, any code that counted on "%" being a regular character for labels in or out of repeats would suddenly stop assembling correctly if SASM was changed to handle "%" differently inside of repeats. Now, how many people use "%" in their label names? Not a clue. I would assume a small number, but I imagine they would be really annoyed when the next version of the IDE stopped assembling their code. Not sure what the best solution would be for this.
    PeterM
    edited 2008-01-15 06:39
    Peter,
    Thanks, I will do it the manual way ($+nn) and just put a comment to check it if I alter the code. In general I am happy with the SX environment compared to other assemblers/compilers.
    Best regards
    Mark
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-01-15 08:46
    The following will generate your example code
    _myjumptable macro
    · local loc
    · jmp loc
    · nop
    loc
    endm
    rept 16
    · _myjumptable
    endr
    (Thanks James, for pointing us again to the power of·macros)
    regards peter
    edited 2008-01-15 18:05
    Peter,
    Nice work! I'm not a real user of macros with the SX (sorry James) so I had to check the manual to see what was going on with your code. Clever stuff. Apparently, the fine folks who originally wrote SASM must have encountered a similar circumstance to Mark. Here's what the manual says (and for those who want to play along at home, it's on page 63) :
    The syntax for the LOCAL directive is
    LOCAL <label>[noparse][[/noparse], <label>]…
    It declares the labels named after the directive as private symbols. Private symbols are available only
    inside a macro body. These symbols are private to each invocation of the particular macro and cannot
    be referenced outside of the macro body.
    The private symbol is used within a macro body just like any other label. Each time the macro is
    invoked, SASM will assign each private symbol a unique name of the form ??0001, ??0002, ??0003, and
    so forth. The unique name will appear in the listing file in place of all uses of the text of the private
    symbol.
    All LOCAL directives must appear immediately after the MACRO directive and before the first actual
    line of the macro body.
    Cool.
    PeterM
    Peter+Peter,
    Thanks very much, I never would have figured that out. Ill give it a go.
    Mark
