Phototransistor Light Sensor
I recently read in a robotics book that I can get better sensitivity with a phototransistor than I can with a CdS cell. Is this true? What kind of circuit would I need to concoct for it to be utilized properly? Thanks!
Giggly Googley!
Giggly Googley!
It really depends on what your application is to warrant which·has better sensitivity.· The question should be completed with "... better sensitivity to what?" Speed? Light Level? Light color?
CdS cells are generally slower to respond than phototransistors, but this·can vary depending on the size of the CdS... larger CdS cells are slower than smaller ones but are more sensitive to lower levels of light because of their larger surface area in general compared to a phototransistor.· If you are comparing characteristics of the human eye, CdS cells are a closer match than a phototransistor.· Phototransistors on the other hand can respond much quicker (orders of magnitude) than CdS, and are most sensitive (usually) to·IR light.
Beau Schwabe
IC Layout Engineer
- Stephen
Giggly Googley!
http://www.parallax.com/Store/Components/IntegratedCircuits/tabid/154/CategoryID/31/List/0/SortField/0/catpageindex/4/Level/a/ProductID/88/Default.aspx
They not only detect light but also detect the light level.
Jeff T.
Giggly Googley!
Post Edited (NoBo780) : 1/13/2008 3:42:46 AM GMT
Jeff T.
EDIT: I modified the sample code to count for 10mS and adjusted the output divisor so that I was getting a reading of between 110 and 180 in a room with soft lighting. Passing my hand between the light source and the sensor would drop the reading below 50.
BTW I'm·one state over·from NC in TN.
Post Edited (Unsoundcode) : 1/13/2008 5:20:22 AM GMT
