servo motor wont work
hello there i followed the book and i was adjusting the servo - motors with the first i had no problem for setting it with pulsout 750 so it wont move, but i cant adjust my other servo motor i tried everything and my program is correct the servo wont stop turning
do i need to replace the servo - motor ???
thx
btw the program i use to adjust the servo:
do
pulsout 12, 750
loop
thx
do
pulsout 12, 750
loop
We have to ask a few question before we can offer any significant help.
Are these ordinary R/C servos, or are they R/C servos modified for continuous rotation. If the latter, were they purchased that way, or did you modify them yourself?
Which model Stamp are you using, and how are the servos being powered? Are they being powered by the Stamp's regulator, or by a separate power source? If the latter, do you have all the grounds connected together?
Lastly, some servos don't have their midband or "center" right at 1.5 ms or a value of 750. Sometimes you have to vary it slightly one way or the other. You mght try 740 or 760 and see if either of those values improve things. My guess is that one of those values should make it significantly worse. If so, try varying the number around the OTHER value.
Bruce Bates
- Stephen
