trouble with xbee — Parallax Forums
trouble with xbee
joeldjoeld Posts: 49
edited 2008-01-12 20:51 in BASIC Stamp
I worked last night on trying to·setup the appbee module·on one of my BS2 carrier boards. I had a BS2SX module in the board and I had one of the Maxstream usb boards hooked to my PC. I programmed both xbee modules with the latest 1083 firmware.
When I try to run the sample code to send a character from the stamp and appbee to the PC board I receive characters on the maxstream terminal window but they aren't what I've sent. I initially thought it might be a transmission or baud rate problem·but I'm getting the same characters consistently and I would imagine they would be somewhat random with a transmission problem. I've tried sending text, dec, hex. Doesn't seem to matter. When I send different characters·the recieved characters on the other end sometimes change but there's no one for one correlation. Other that this everything appears fine. When I reset the appbee the transmission stops. The transmissions are in sync with the basic program I have the character debuged to the screen before it's serout line.
I'll keep reading and troubleshooting but maybe someone has seen this and can narrow down my troubleshooting.
