Compass Sensor Issues!
Compass sensor plugged in, and "supposedly" calibrated properly. At first it seemed to work properly but then (no matter where, different rooms, hundred - 2 hundred feet apart, up and downstairs), when it faced East, it would jump randomly, despite the other directions working. However, it did seem to work properly in the spot we calibrated it. So we decided to calibrate it somewhere else. Now it's simply not moving more than about 5 degrees +/- of 60.
Any ideas?
Any ideas?
It sounds like it might be mounted too close to something magnetic. Is it mounted near one of the drive motors (servos)? If so, you'll need to move it UP or otherwise out of the way.
Bruce Bates
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
