12v 500mA ok?
I've got a BS2 Rev J and a BOE Rev C. I wasn't able to get it to identify on my computer until I chucked out all the 9v batteries I found around the house and used a 12volt 500mA wallwart instead. Now it works, but I'm concerned about feeding it too much voltage. Are there any potential problems running it like this? Would I be able to complete the "What's a Microcontroller?" course using this power supply?
One way to check: plug the supply into the wall, and without it plugged into the board, check the voltage produced·with a multimeter. If the voltage is around 12, you are safe.
Judging from that, it looks like the 12V power supply is ok. I'm pretty sure the wall warts Parallax sells are not regulated.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
