Everyone loves RAM — Parallax Forums
Everyone loves RAM
Graham StablerGraham Stabler Posts: 2,510
edited 2008-01-14 19:19 in Propeller 1
Everyone wants more RAM and one way to get it is with external RAM chips and possibly a CPLD etc but I was wondering if Parallax would or could create there own RAM device with an integrated interface particularly suited for the propeller and its programmers, something easy to set up and drive and with handy modes such as FIFO, pseudo DMA etc. This would allow for three chip (prop, RAM, ROM) super systems.
I'm afraid I'm ignorant of the practicalities of such an idea but I thought I would put it out there in cased it wasn't totally mad.
Graham
  • rjo_rjo_ Posts: 1,825
    edited 2008-01-10 14:33
    Graham,
    I think Andre is on that track. With his new card, you even get a CPLD, which you can re-program (that's a capital "YOU"... not the little "me" [noparse]:)[/noparse]
    Problem is that the key info for the card is on a CD, which you don't get to see unless you buy the card. I looked around for a technical description of his new card for the Hydra and had great difficulty finding it. I don't know if there is a limited supply, if Andre really doesn't want to sell the new cards or what, but I think that card is the best kept secret in the Prop world[noparse]:)[/noparse]
    I think this would be another great section for the Propeller Cookbook.
    Rich
    edited 2008-01-10 15:18
    The Hydra 128K Expansion board adds a second 128K EEPROM plus some expansion wiring area, but no RAM.
    The RAM card is described here:
    www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/CategoryID/19/List/0/SortField/0/Level/a/ProductID/444/Default.aspx
    Post Edited (Mike Green) : 1/10/2008 3:26:17 PM GMT
  • hippyhippy Posts: 1,981
    edited 2008-01-10 15:29
    More likely this one ...
    The HYDRA Xtreme Manual explains teh workings, describes the CPLD, reprogramming and includes the CPLD re-programming interface.
  • DroneDrone Posts: 433
    edited 2008-01-10 15:44
    Oh yes - I got the wrong card, thanks for the corrections...
    There's a thread on adding RAM here http://forums.parallax.com/showthread.php?p=618562, I think this is in the Sticky good thread index...
    David
    edited 2008-01-10 15:48
    Rich,
    I was aware of those cards "external RAM chips and possibly a CPLD etc" but they are not practical for many applications (too big) hence my post.
    Graham
    edited 2008-01-10 15:49
    Oh when I ask if Parallax could create there own RAM device I mean a single IC
    Graham
  • BaggersBaggers Posts: 3,019
    edited 2008-01-10 17:10
    how much ram are you after? if it's ~32K they do already it's called a second propeller [noparse]:)[/noparse]
    edited 2008-01-10 18:52
    I'm not after any amount in particular but I guess I was thinking of larger amounts suitable for image capture and the like.
    Graham
    edited 2008-01-10 19:55
    Something like 128K sram?
    Don't forget you've gotta be able to get the address and CE etc then data fast enough for it to be usable, so tbh you'd need something like a small cpld ( like HX512 setup ) where cpld can be given start address etc, then just burst read / write from that address, then the cpld handles all the pre-post inc/decrementing for you, instead of the cog struggling to keep up.
    Baggers.
    PS, and unlike hubram, only 1 COG will be able to assist with accessing the extra ram.
  • lairdtlairdt Posts: 36
    edited 2008-01-10 22:09
    I found adding a 32k FRAM (Ramtron FM31256) gave me what I needed, plus clock and 2 event counters, all on the same I2C bus as the boot eeprom.
    edited 2008-01-10 22:19
    If you're looking for (relatively) easy to use video memory, you can use the CY7C09089V: http://rocky.digikey.com/WebLib/Cypress/Web%20Data/CY7C09079V,89V,99V,%20CY7C09179V,89V,99V.pdf·64KB of dual port RAM with burst mode, fill it up via one port connected to the Propeller, drive the video from the other port in burst mode. But this ease of use doesn't come cheap, the chip costs $38 (and it is not RoHS compliant).
    Paul Baker
    edited 2008-01-10 23:03
    Baggers, the function of the CPLD could be built into the RAM chip presumably if it was custom.
    Again I have no real application I'm just trying to suggest that the kinds of devices many people would like to see do not exist (except for $38) and I wondered if parallax could create the hobbiests dream RAM chip complete with built in interfacing logic.
    Graham
  • VIRANDVIRAND Posts: 656
    edited 2008-01-11 05:02
    How about driving DRAM SIMMs salvaged from old PC's? Just needs some really cheap glue logic to save I/O pins.
  • FrobozzFrobozz Posts: 12
    edited 2008-01-11 06:10
    VIRAND said...
    DRAM SIMMs have to be refreshed though. And they're not exactly fast. I just checked a stick from a stash of old memory I have and it runs at 70ns. Also good luck finding a socket for SIMMs.
  • Dennis FerronDennis Ferron Posts: 480
    edited 2008-01-11 06:37
    Interestingly, if you do manage to find a socket for sims (I got 1 from a surplus store) it will fit perfectly on a breadboard. On 30 pin sims, the pin spacing is the same as DIP chips.
    edited 2008-01-11 08:46
    70 nanoseconds seems fast enough for me;
    if I calculated right it's 14 Megabytes (or Mbits or Mnybbles if using only one DRAM chip) per second.
    Refresh requirement probably is 1024 reads every 4 milliseconds. Such as if using some of the DRAM as the video buffer.
    Why not solder onto a simm? How about soldering header pins on it?
  • deSilvadeSilva Posts: 2,967
    edited 2008-01-11 08:56
    When using a COG as DRAM controller it can of course do the refresh as well: around 10 additional instructions smile.gif
    edited 2008-01-12 20:14
    Jameco sells 30-pin sockets for $1 each. The SIMMs themselves are pretty common on Google's product search engine - tried a quick search for 4MB and they pop up around $5. 16MB pops up at around $20. Nice cheap easily soldered memory.
    Not that I need to order SIMMs any myself. I just found 13 in a small memory box I dug up from old $5 386s. I think I have some 256KB ones someplace. [noparse]:D[/noparse]
    Post Edited (Frobozz) : 1/12/2008 8:19:27 PM GMT
  • Mike PopoloskiMike Popoloski Posts: 10
    edited 2008-01-13 13:46
    Just out of curiosity, what would be the speed differences between this DRAM version and the more complex SRAM with CPLD controller? Enough to discredit the use of the DRAM as video memory?
    edited 2008-01-13 13:56
    Perfect would be 30pin SIPPs
    (30 pin SIMM with pins) but I haven't seen one of these in years...
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook
    Got an SD card? - PropDOS
    A Living Propeller FAQ - The Propeller Wiki
    (Got the Knowledge? Got a Moment? Add something today!)
    edited 2008-01-14 14:52
    eBay has a few SIPPs and a good number of 30/72-pin SIMMs for sale.
    search.ebay.com/search/search.dll?ht=1&from=R4&satitle=sipp&sacat=58058%26catref%3DC6
    search.ebay.com/search/search.dll?ht=1&from=R4&satitle=simm&sacat=58058%26catref%3DC6
    Edit: Where is a good document detailing how to use 30-pin SIMMs? I've searched JEDEC but their site got changed and
    now I can't find anything. I hate it when something gets changed for the worse.
    Post Edited (Frobozz) : 1/14/2008 4:36:34 PM GMT
    A good source for legacy DRAM chips and modules is Jameco. I'm not sure I'd want to design an actual product around these, though, since they're not made anymore. Nonetheless, they seem like a good match for the Propeller's capabilities and pin count.
