Networking question
to be short I'm having RF Issues on my web controlled bot. I'm really liking what I see with roborelm and so I decided to put a PC onbaord for the vision control software. it will have a wireless connection to the internet.
My question: If I put the PINK onboard add a second NIC to the computer and bridge the to network cards that will give the PINK internet access right?
is their any performance loss with this method?
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
DGSwaner
thanks
DGSwaner
If the answer is yes (as might be the case to support some pre-existing configuration) and the computer is running Windows XP, I may be able help in configuring the computer to share its wireless connection through its hardwired network connection.
Let me know if this is the case.
- Sparks
DGSwaner
Diablo, where were you 18 months ago, i looked and look for info or people to help me do just that, then the pink came out and so i picked up one to solve the problem. could you tell me a little more about what is involved? can I set up a series of server variables? I don't know which way would be best. I already have the web interface working with the pink, but I do have space limitations with the pink.
thanks for the input
DGSwaner
I use a desktop but you are right about bridging.
My desktop has a wifi connection with a router. My pink is connected to a wired lan card
in my desktop, using the (red) crossover cable supplied with the pink.
I assigned my pink a static address 192.168.2.70 (I used 70 because the pink is a SB70 print
which makes it easy to remember).
All you need to do is open network connections, select the two networks that you like to bridge,
(hold down CTRL and click on both networks), then rightclick and select bridging.
(This is on a XP SP2 machine). After that I could sent emails, and send/receive udp messages
from the desktop·and I didn't even had to adjust firewall settings.
Edit: an option for a fast bootable mobile solution would be an eee pc from asus.
regards peter
Here are some of my ideas/suggestions:
As far as boot times and such I have two suggestions: One I'm fairly sure isn't legal and the other cost money :P
*NOTE: I do NOT condone piracy in any form, This information is ment to be educational
[noparse][[/noparse]Please share this information privately through e-mail - Forum Moderator]
[noparse][[/noparse]DiablodeMorte] - Ok, sorry, Note to readers: TinyXP is the non-legal solution
As to my knowledge, this method is legal. In this method, a piece of software is actually bought that then uses a legal version of windows and strips out all the unneeded things. About 30 seconds of google search discovered this peice of software: http://www.litepc.com/xplite.html. I've never used this software but it seems to be for more "advanced" users.
As for more information on by post suggesting the use of a webserver on the PC. It might be more beneficial if we talked over IM. If you could just send me a Private Message I'm sure we could work it out.
Post Edited (DiablodeMorte) : 1/12/2008 5:14:57 AM GMT
