Counter speed?
How fast are the counters? I've looked through the spec. in the manual but couldn't find anything.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
From what I understand.. 1/2 the clk speed .
So if 80MHZ (PLL 16 * 5 MHZ crystal) the max count speed is 40MHZ
That's using the CTRA / B hardware ..
Ron Mel oz
Leon
The main, basic, and overall activity of the timers/counters is to add FRQ to PHS each system clock cycle (e.g. 12.5 ns)
All other things depend on the specific mode they are in.
In NCO mode the eventually resulting bit31-strobe can be frequency multiplied by 16 (and after that optionally divided by 2,4,8,16,32,64, or 128).
Post Edited (deSilva) : 1/9/2008 5:45:38 PM GMT
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Re your question " How fast are the counters "
Do you mean the speed of the internal cntrs for the purpose of generating signals or
do you mean how fast can a cntr collect pulses coming from an outside source..
An outside source for example being a rotary encoder or a high speed sensor...
I think my answer of 40MHZ is correct if your talking about counting external pulses..
Whereas the Propeller can generate pulses at higher frequencies internally...
cheers Ron Mel OZ
Leon
Yes I agree we are on the same "WaveLength"
It is or must be confusing to some people as "ALL" is referred to as "Counters"
A counter to most people is a device that collects pulses and adds them in a register ..
These counters are used in the propeller internals to do trickery like PWM DUTY cycle... pulse in width measurement..
All answers as I see in this post are correct ..
cheers Ron Mel OZ..
Post Edited (OzStamp) : 1/10/2008 1:33:44 AM GMT
A rising edge perhaps?
Then you can count "spikes" of >12.5 ns each "spikewidth" + 12.5 ns.
The reason is that a spike of <12.5 ns will not neccessarily be sampled, also a smaller "gap" between spikes need not be identified...
You just set the counters to "edge mode"
