Pink serout data
hello
i need some help and finding a solution to a problem.
i have some logged data in a stamp. 6 fields and 10 records
using the ptr system, is their a way i can serout this info to
the pink module. cant seem to cascade the logged data
can only read the last record in the run. debug's ok in the
terminal. has anybody had this problem before,
or is their a way to monitor the <nbvar> in the web page
and log a change. been on it awhile any help or clue in the right direction would be appreciated
thank you
japer
thank you
japer
you should easily be able to send and store the data to the pink via SERIAL. you can view the variables on the PINK variable config page or make your own web page and just list the vars how you want them <NB_var00> will display as the value for that variable.
it sounds like your writing the data to the same variable, you need to increment the variable for each field. on your serout statement add a variable that you can incrament in place of the var number.
with out knowing more specifics or seeing your code that's the best I can do.
hope that's a little help!
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
sorry i havent responded quickly thanks for your quick reply.
to answer your question, yes i can not figure ,how to incremental change the "!NB0W" value as the ptr
loops attacked is the code . it will work in the debug terminal and stop the loop when commanded
from the web page but cant seem to figure the ("!NB0W" )+ 1 command
thank you
japer
here is what you need to do
varDATA = "hello world"
FOR x = 10 TO 20
SEROUT 4,396,[noparse][[/noparse]"!NB0W",DEC x,":", VarDATA, CLS]
NEXT
the actual serial data sent is "!NB0W10:hello world"
10 being the value of X
so in the for next loop you need to make sure that you have enough places for all of your data.
hope that helps
DGSwaner
Post Edited (Dgswaner) : 1/9/2008 4:22:27 PM GMT
thanks for your input it has me on the right track .
as it will point to the next Nb_Var ,but still READs the last input of the ptr
to the next Nb_Var. also is seems to throw the timing off also
it does work well to clear all the varibles at on time.
as with
for x = 01 to 06
serout 4,396.[noparse][[/noparse]"NBOW",DEC2 x, ":0",CLS]
next
thanks
japer
Thanks to Dgswaner pointing in the right direction
changing the order of the nested loops
it work's beautiful will post code tonight
japer
One thing I noticed doesn’t look right in your code is that you’re using a letter ‘O’ instead of a number 0 in the “NB0W” section.
heres the code that works
thank Mr Savage for pointing out my typo it is a (0)
found that out the hard way when started using Pink
thanks again
