Code review: Mobile robot
This is my first real SPIN project. can I get a review from the experts (or anyone)? I'm looking for advice on how to make things simpler, better and faster. as well as any other type of advice related to programing.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000 'Note Clock SPEED for your setup!!
PINGServo = 0 ' PING pan servo
PING_Pin = 2 ' I/O Pin For PING)))
propTX = 30 ' programming output
propRX = 31 ' programming input
CLEARDIST = 18 ' bot will go forward until < cleardist
TURNDIST = 45 ' bot will turn until > then turndist
VAR
LONG RANGE ' PING sensor DISTANCE
LONG OLDRANGE
LONG DIRECTION[noparse][[/noparse]6]
LONG DISTANCE[noparse][[/noparse]6]
BYTE HLIGHT ' headlights 1=off 0=on
BYTE DEBUGSEMID
LONG INDEX ' lock to be used by debug
LONG SPEED
BYTE CLEAR
OBJ
SERVO : "Servo32v3" ' servo vontrol
ping : "ping" ' PING control
go : "motor control" ' HB25 controller
Sound : "sound" ' sounds for bot
debug : "MultiCogSerialDebug" ' debug serial driver
PUB init | TEMP
go.start
dira[noparse][[/noparse]23]~~ 'set PIN 23 for output, for headlights
HLIGHT := 1 'turn off Headlights
Headlight
sound.ready
SERVO.Start
repeat temp from 0 to 1 'Preset ALL servo's to center position
SERVO.Set(temp,1350)
debug.start(propRX,propTX,0,9600,DEBUGSEMID)
SPEED := -2000
MAIN
PUB MAIN
CLEAR :="n" 'assume it's not CLEAR to go
repeat
PING_AROUND
SET_SPEED
if DISTANCE + DISTANCE < DISTANCE + DISTANCE
CLEAR := "r"
if DISTANCE + DISTANCE > DISTANCE + DISTANCE
CLEAR := "l"
if DISTANCE > 15 and DISTANCE > 15 and DISTANCE > 15 and DISTANCE > 15
CLEAR := "y"
case CLEAR
"y" : IS_CLEAR
"r" : TRTC
"l" : TLTC
PUB IS_CLEAR ' all clear go forward
SOUND.BEEPS(1)
GET_DISTANCE
SET_SPEED
GO.FORWARD_SPEED(SPEED)
repeat while RANGE > CLEARDIST
GET_DISTANCE
go.stop
CLEAR := "n"
MAIN
PUB TLTC ' Turn Left 'Til CLEAR
SOUND.BEEPS(2)
RANGE := 0
SERVO.Set(PINGServo,900)
waitcnt (10_000_000+cnt)
REPEAT WHILE RANGE < TURNDIST
GET_DISTANCE
go.left
GO.STOP
MAIN
SERVO.Set(PINGServo,1350)
PUB TRTC ' Turn Right 'Til CLEAR
SOUND.BEEPS(3)
RANGE := 0
SERVO.Set(PINGServo,1700)
GET_DISTANCE
go.RIGHT
GO.STOP
MAIN
PUB PING_AROUND| TEMP 'Pan PING around to 4 spots then center
INDEX:= 1
temp := 0
oldRANGE := 0
repeat INDEX FROM 1 TO 5
TEMP := LOOKUP(INDEX: 1700, 1600, 1100, 900, 1350)
SERVO.Set(PINGServo,TEMP)
waitcnt (30_000_000+cnt) 'wait for servo to get to it's position
GET_DISTANCE
DIRECTION[noparse][[/noparse]INDEX] := temp
DISTANCE[noparse][[/noparse]INDEX] := RANGE
if RANGE > OLDRANGE
DIRECTION := Temp
oldRANGE := RANGE
PUB GET_DISTANCE
RANGE := ping.Inches(PING_Pin)
waitcnt(clkfreq / 10 + cnt)
PUB HEADLIGHT
case HLIGHT
0: outa[noparse][[/noparse]23]~~ 'turn on headlights
1: outa[noparse][[/noparse]23]~ 'turn off headlights
PUB SET_SPEED | A
repeat A from 1 to 5
if DISTANCE[noparse][[/noparse]A] > TURNDIST
SPEED := -2000
else
SPEED := -1700
DGSwaner
DGSwaner
