Part numbers, how to find?
I am reading an article in nuts and volts http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv25.pdf· page 259 and it mentions a
National Semiconductor LP2951 which is a 5v regulator with an on/off pin.
I search mouser for lp2951 and find 100 numbers but nothing from National Semiconductor. I look and can't find anything with on/off pin. I am not going to seach 100·datasheets looking for an on/off pin. ·
Can anyone recommend search tricks for mouser on how to find specific traits?
I.E. ·I want a 5 v regulator that has an on/off switch?
Does anyone have a database perhaps or spreadsheet with components they use I could get?
· As I get into this I find thousands of components and usually grab what is recommended by fellow propers. I have just realized there is a load of electronics info·on the stamp pages. I can handle the software side but since I was an electronics technician when 5 transistors on a chip was miraculous, I never did any design work and there is alot to learn.
·Again, thanx to everyone for their help.
Mosquito: An animal which buzzes in your ear and never stops. He may byte you, he may nibble you, but you will know you were bit.
Technologically challenged individual, Please have pity.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
The very first link it suggests is this
www.national.com/mpf/LP/LP2951.html
I open it...
100% success, took 4 seconds...
those are pretty cool. an Error pin also. cool!
DGSwaner
o.k. I typed "LP2951" into digi-Key
I select "available" and "DIP
there were 2 results one for 3V and one for 3.3V, both 100mA
But I donot need one
Try [noparse][[/noparse]http://findchips.com/avail]
You will found more than 20 distributors for that chip.
Regards.
Alberto.
Dgswaner: I cant find a 2950-d. I searched LP2951 and found 65 hits.
Desilvia: same again, "I don't need one but felt I had to type something"
Folks: The question is " How to improve search results" Only answer on topic is Phil. I guess I will switch to digikey on his recomendation. Thanks Phil
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
http://octopart.com/
It's not our fault that it will take you some time to start-up to things that are obviously all very, very new to you...
Remember. "There is no king's road to microcomputing" (Euklides, 300 BC)
·Senario:
· I am flying from Los Angeles to Las Vegas and my alternator quits. Is there a system that will notify me off this condition and shut off my battery contactor and turn on my essential bus?
· I would consider this a newbie question and not have to answer it unless I happen to be online when it is posted. There normally would be 5 answers in 1/2 hr. No sandbox remarks, no snide remarks.
· God I wish I could know everything.
·I need a system that shuts down my battery
Post Edited (mosquito56) : 1/8/2008 10:55:10 PM GMT
You closed the question, we can now all sleep sound tonight. You asked a question that was not relevant to this particular Forum. How does or did your original question relate in the slightest to the Propeller. You had a problem being able to navigate a different companies web site. Easy solution either take it up with them, or possibly find
a different supplier. I've not been nasty. Have simply offered you two different solutions.
Mike.
Paul Baker
