Using a thumb drive with the prop.
· I noticed a bunch of software for the thumbdrive on the stamps pages. Not sure if that is the correct name. USB 2gig modules that cost about $15 now. I ordered the module from parallax last week and was wondering if anyone had seen any spincode for this module?
·· Also, are usb ports complicated to wire up? I have no idea how USB works. A point to wikki or something would be useful. Incorporating a 1 gig storage device is a must for my project.
Mosquito: An animal which buzzes in your ear and never stops. He may byte you, he may nibble you, but you will know you were bit.
Technologically challenged individual, Please have pity.
http://forums.parallax.com/showthread.php?p=696804
On the object exchange page are also spin objects for serial mode
and spin objects for other datastorage devices.
http://obex.parallax.com/
regards peter
· I have downloaded every object in the object exchange but I don't remember seeing this object for the prop. I don't want to re-invent the wheel so I thought I would check here if anyone had seen one. When I get to the point in my project where I will need the drive and don't find one first, I will share mine on the obex.
· _clkmode = xtal1+pll8x
· _xinfreq = 10_000_000
to
· _clkmode = xtal1+pll16x
· _xinfreq = 5_000_000
then you can use it on the propeller demo board.
The bundled test program uses spin stamp pins SOUT and SIN
for debugging. On the prop board you need to use pins 30 and 31.
regards peter
So just download those Spin files and play with them. Peter is an excellent programmer and the object looks like it'll do everything you need. Just in case you need the link again: http://forums.parallax.com/showthread.php?p=696804
Harrison
Post Edited (Harrison.) : 1/8/2008 6:40:19 PM GMT
or any of the other boards also used by basic stamps. If you don't have any of these
boards, you can use the propeller protoboard.
regards peter
·I have downloaded all of Peters programs and will report as soon as my order comes in if you still want feedback on the program.
