Question — Parallax Forums
Question
NoNo Posts: 26
edited 2008-01-08 18:41 in Robotics
How come the lower end hitec servos (hs50,55, etc) arent used to build humanoids? is it because there onot digital, and dont have as much holding power? I would really hope/like to build one one day, although its a pretty expensive project.
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2008-01-08 13:18
    No -
    This is just an educated guess, but I'd imagine that anyon'es "low end" servos probably don't have sufficient torque for a "humanoid" robot. Of course it all depends on how large the "human" replica is smile.gif
    Bruce Bates
    edited 2008-01-08 14:18
    If you take a look at some of the low end servos
    not designed for humanoid robots, they have a
    startup power on movement when they are first
    pulsed. This moves the servo horn to an undesired
    position. While this is readily accepted for bipeds
    and more simple robots with fewer servos, in more
    complicated robots the movement of many servos
    to an out-of-home position could have some
    undesired results.
    I tried some low end servos for a humanoid robot
    and aside from the challenge mentioned, the
    servos adequately performed with sufficient
    light weight materials. In fact, there are companies
    manufacturing humanoids using some low end
    servos, in Asia. By keeping the servo cost low,
    and using a low cost servo controller to handle the
    overhead, a Basic Stamp such as the 2px is well
    suited, fast, and ideal for interfacing to a servo
    controller. Plus, there's a lot of Penguin Robot
    software available to run on this platform.
    humanoido
  • NoNo Posts: 26
    Thanx guys for the clarification. ·I would hope to make that a long term project once i get a lil more advannce with the programming.·Humanoido you have any pic of that humanoid project you did? where yo able to have it do multiple things at once? i was told i would need an SX or Prop (of the parallax family)· if i wanted to control multiple servos at once.
